Old 04-09-2004, 06:38 PM
belezeebub belezeebub is offline
belezeebub is off the scale
After reading this and other boards it seems to me that the H2 has some "Issues" with out starting a Flame war (I hope)
I am not as wealthy as some of you (it has taken me 3 years to save up thye money for a Hummer) and Need a Truck that I can drive everyday and one that doesn't break down all the time.
I have seen posted about leaks, tie-rods, fuel, computer issues, electrical issue, transmissions and a ton of others
So here are Yet more questions.
1. How often has your H2 been in the shop?
2. How often does it break down?
3. What kind of issues have you had?
Given that this WILL be my daily driver and only car should I get one?
“Slow response”
You must be imagining it,
Your port is routed Via a Net Optics Net1000SX to a Finisar Multi-Mode GBIC, from there your packets Travel over a 850Nm Laser connection to our High speed 7800KB/sec Max Optical Storage device, I see
“Slow response”
“Slow response”
Old 04-09-2004, 06:44 PM
Longhorn's Avatar
Longhorn Longhorn is offline
Longhorn is off the scale
Great, your one of "those" spineless types who needs to be coddled. I thought you just had a laundry list of add ons all picked out and now you can't pull the trigger?
I can't decide for you and I'm not going to rationalize a 60k purchase for you. Be a big boy and show mommy which car you want.
If you need any help deciding on lunch tommorow, call me.
Old 04-09-2004, 06:45 PM
Longhorn's Avatar
Don't buy it, it will be in the shop all the time for oil changes, tire rotations and other really scarry stuff. Oh, they'll also provide a rental car for added inconvenience.
Old 04-09-2004, 07:01 PM
Gee ask a question and get a personal attack, you are truly number one in my book can you guess which finger I use to signal that?
I don’t consider these Normal problems, on a 60000-dollar car.
OUTPUT SHAFT-Drivers Side-DEALER?
Air Suspension Went Out
RECALL-Ignition Switch Replacement
TSB - Engine Continues to Run When You Take the Key Out of the Ignition
Front Diff Output Seal Failure
Air Suspension Problems
intermitent noise
STUCK H2 BLOWN INJECTORS!!!
climate control burned out?
power steering pump again
Front Side Windows Inoperative
" " " Heated Seats Inoperable
" " " Door locks Inoperable
After starting car and driving doors do not lock
After turning car off, Radio, door locks and windows do not operate
Remote Keyless Entry (RKE) inoperative.
My right wheel fell off...
Service Air Suspension?
transfer case control buttons not responding
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by LonghornRockcrawler:
If you need any help deciding on lunch tommorow, call me. <HR></BLOCKQUOTE>
“Slow response”
Old 04-09-2004, 07:04 PM
Longhorn's Avatar
Then don't buy it, but don't ask me for reassurance or to convince you.
The sky is falling.
TROLL!
Old 04-09-2004, 07:20 PM
Thank you Alec W, I am still deciding about it and as for you Mr. LonghornRockcrawler
Were you born an *******?
Or did you work at it your whole life?
Either way it worked out fine
'Cause you're an ******* tonight
Yes you're an A-S-S-H-O-L-E
And don't you try to blame it on me
You deserve all the credit
You're an ******* tonight
You were an ******* yesterday
And I've got a feelin'
You'll be an ******* the rest of your life
And I was talkin' to your mother
Just the other night
I told her I thought you were an *******
She said, "Yes, I think you're right"
And all your friends are *******s
'Cause you've known them your whole life
And somebody told me
You've got an ******* for a wife
'Cause you're an aaaass...hole tonight
The sky is falling.
TROLL! <HR></BLOCKQUOTE>
“Slow response”
Old 04-09-2004, 07:40 PM
Longhorn's Avatar
Thank you kind sir for the witty retort. Have yourself a weekend!
I'll be available if you need any more help making those pesky decisions that life seems to hurl your way.
Old 04-09-2004, 07:50 PM
frank6150's Avatar
Mine was in the shop one time due to the on-star unit not functioning. I should have just left it broke cause now I spend more money than I am comfortable with using the phone feature. It is addicting.
Other than that I have had to touch up some rusty bolts and just check fluids now and then. I beat my truck pretty good, nothing compared to some of the people here but I am far from gentle with it.
My Silverado was in the garage all the time for little problems and I never treated it as rough as I do this truck so I'm pretty happy about that.
No matter what your decision winds up being you will have something go wrong here or there but you will never be stuck without a vehicle since they will always give you one to drive. Hell they come pick my truck up and bring it back to me just for an oil change so I can't complain since it is a little over an hour to get to the dealership.
Old 04-09-2004, 08:09 PM
good luck on your choice!
For what it is worth, this is just another GM vehicle! You may get lucky and have no problems, you may be unlucky and have a ton of problems. I have owned many GM vehicles (mostly trucks) and this one has made me very happy! I have had trouble with my compresor! That's it other than minor issues! This is still a fairly new truck and needs some kinks worked out (compressor) and if you take care of it, it should take care of you! i can't make the choice for you, but, I can tell you I am glad i got mine!
Old 04-09-2004, 10:25 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by belezeebub:
....should I get one? <HR></BLOCKQUOTE>
No, Mrs. Beezly, you shouldn't. It's a really long drive from Hillsburrito to the Hummer dealer. You'll be subjecting yourself to that awful traffic on 26 and all of those grumpy econo-box drivers that will be giving you dirty looks will probably make you really uncomfortable, too.
Get a Hyundai. You'll blend right in.
Old 04-09-2004, 10:51 PM
Golly gee.......
Were you born a troll?
'Cause you're a troll tonight
Yes you're a T-R-O-L-L
You're a troll tonight
You were a troll yesterday
You'll be a troll the rest of your life
I told her I thought you were a troll
She said, "Screw him, a-ight"
And all your friends are trolls
You’re not old enough for a wife
Or did you work at it your short life?
'Cause you're a complete aaaass...hole!!!!!!
Old 04-09-2004, 11:44 PM
OldHiker OldHiker is offline
Don't pay attention to these people.
I’ve had mine since the end of January. The abs light came on and stayed on. It seemed one of the modules shorted out. No problem, dealer fixed and yes, I did get a loaner to ease the inconvenience of not having the truck.
Around town or highway driving is simply amazing. I love the way it rides. Never had it offroad, so I cannot comment on that aspect of it. I’ve had several Jeeps, Cherokee’s as well as many Grand Ltd’s, and Navigators (the most boring vehicle on the planet). Mileage on the Jeeps was marginally better and the Navigator worse.
But every time someone gives me the thumbs up or comments on how they wish they could get one, it brings a big smile to my face. That makes up for any and all inconveniences I will or may incur during my ownership.
If you can do it, order one asap. Your pleasure and pride will outweigh anything else.
Old 04-09-2004, 11:55 PM
(said with Spicoli voice from Fast Times at Ridgemont High) duuuuude, it's oldtoker smokin' the fat one and jumpin' on the keyboard again. Are you one of those guys that smells like dope 24/7? Do you have dreadlocks? How many Grateful Dead bootlegs do you have stored in your drug bus?
Beezlebub, H2 warranty and maintenance is good, bugs should certainly be worked out by now. Don't get an h1 because the cheap bastards at amg won't even pay for a $30 rental car.
Old 04-10-2004, 12:17 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Just get one, so you can have bragging rights. Because as of now, you have no rights. The feling of being an H2 owner cannot be described in words.
Get one, and you will understand.
Till then, you are just blowing hot air out your ars.
Ric-H2
www.meatspin.com
Old 04-10-2004, 01:02 AM
Bee, like Buffet?
http://www.orbyonline.com/archives/000638.php
Old 04-10-2004, 01:19 AM
Navigator is off the scale
intermitent noise
<HR></BLOCKQUOTE>
Then dont get one you worry wort. If you go to any vehicle specific forum like this you will see a few bugs that need fixing for some of the guys, and a few guys that have really bad luck, but you will also find guys who havent had a single problem.
Buy a used car and put the rest in a retirement fund if you are that concerend.
Rich
Mods & Pics
Old 04-10-2004, 01:36 AM
HGW HGW is offline
HGW is off the scale
It is still a GM vehicle and therefore a crap shoot. They can't build a vehicle to save their own lives. Do you like it or not? I love mine but have no expectations that it will not break.
I have had a Lexus, BMW, Honda, Toyota--never ever a service call--about 300,000 miles--My Hummer rattled off the lot. I just bought another one.
