Old 05-09-2004, 01:57 AM
So Cal H2 So Cal H2 is offline
So Cal H2 is off the scale
Today I started the install on the H2 It was a long day but I got the front done. I will finish the rear tommarrow and let you all know how it went Here is a pic of the kit.
2003 Blk H2 Lux,CST 6\" Lift,Fox Shocks
20X10 Kaotik Wheels 38X15.5X20 Toyo M/T
Magnacharger,Volant Intake,Volant S/S Exhaust.
Old 05-09-2004, 02:25 PM
HGW HGW is offline
HGW is off the scale
What shocks are you using?
Also, what is CST? Have not heard about them but I like the kit----did you have to do any cutting?
Old 05-09-2004, 10:01 PM
CST California Super Trucks
http://www.californiasupertrucks.com/
Shock are made for this kit for the H2 They are CST Shock
Yes Had to cut off the stock bump stop mounts
Old 05-09-2004, 10:59 PM
HGW HGW is offline
Thanks for the info----it is a kit to consider since it has true control arm drops and does not appear to spread the upper and lower control arms. I also like the heim joints. More guys on here should use heim joints since they break tie rods off road.
I went with the FTS 6.5 lift and it really does ride like stock--they do the same thing. I went with King Off Road shocks, more for show than anything else. It gives the lift a real beefy look.
On my next lift, I will go with other, less expensive shocks.
Old 05-10-2004, 02:09 AM
H2 How do you like the Magnacharger any problems ? Do you have a pic of your ride I would like to see it Thanks
This is what mine looks like
Old 05-10-2004, 09:02 AM
HGW HGW is offline
Looks good so far----I do not know how to link to a previous post but if you go to the photo section and scroll down to "Weld Cheyennes on 38 X 15.5 X 18" you will see numerous pics of my Yelllow H2.
The Magneson is fantastic---I will post pics once I get a chance.
Old 05-11-2004, 11:57 AM
H2 Nice rig looks great!!
Here ia a pic of the suspention
Old 05-11-2004, 12:00 PM
2nd pic
Old 05-11-2004, 12:05 PM
Pic of the finished lift with wheels
Old 05-11-2004, 10:50 PM
HGW HGW is offline
Looks good--when you get a chance, I'd like to see a pic on the steering system up real close---that has been a problem on some lift like this---looks like they did a good engineering job on it.
Also---did you get rear brackets to lower your trailing arms--it looks like it but I can't see it in the pics with the tires on.
I would also like to see the shocks when you get them on.
Old 05-13-2004, 02:29 PM
Tbone Tbone is offline
Tbone is off the scale
Looks nice. How do you like it? Is the CST kit a solid kit? How does it handle and drive?
Send more pics if you have them.
Old 05-15-2004, 01:19 PM
H2 I will get a pic of the steering for you. Trailing arms are in the stock location.
Here is a pic of the shocks.
Tbone So far I really like the kit. Yes it is solid and it rides and handles better than stock I will get more pics later.
Old 05-15-2004, 01:21 PM
pic 2
Old 05-15-2004, 02:39 PM
HGW HGW is offline
Thanks for the pics--I thought they would leave the trailing arms in the stock location.
The shocks look good!
Old 05-16-2004, 02:51 AM
H2Oguy's Avatar
H2Oguy H2Oguy is offline
H2Oguy is off the scale
Well done So Cal! Very Nice, I did not think I would want to go with that big of a lift on mine but seeing your set up makes me think twice.
www.h2ohummers.com
"Nothing Else Compares"
Old 05-16-2004, 01:06 PM
Thanks for the complements I like the way the lift came out it sits level not too high no drive line vibration no wheel rubbing on full turns and handles great. My only complaint would be the loss of power with the 38" tires but that can be fixed
Old 05-16-2004, 03:17 PM
HGW HGW is offline
The loss of power is definately noticable with 38's. I have a Magneson on mine and notice too much of a drop during 6000 RPM manual shifts between gears.
4.56's will solve the problem easily. Now that you have the cage underneath, you will need to drop it again to remove the front diff.
I still need to see the front steering system when you get a chance to take them.
Old 05-17-2004, 01:12 PM
Hummer Man is off the scale
So Cal H2, Thats looks great - I love those wheels!
