Old 03-16-2004, 01:04 AM
Zing's Avatar
Zing Zing is offline
Zing is off the scale
Anyone come across a loud horn that doesn't require and air compressor? Was there another thread on this?
H2 '04 Black
Zing's Avatar
H2 '04 Black
Zing's Avatar
H2 '04 Black
Old 03-18-2004, 12:43 PM
ATRH2's Avatar
ATRH2 ATRH2 is offline
ATRH2 is an unknown quantity at this point
I've been looking also. Have not seen anything.
Old 03-18-2004, 05:47 PM
Dick Renaud's Avatar
Dick Renaud Dick Renaud is offline
Dick Renaud is off the scale
Try these
http://www.safetyleague.com/Products...s/airhorn.html
http://www.safetyleague.com/Products...4P_speaker.htm
This will give you the air horn you hear on firetrucks and a PA
Old 03-19-2004, 01:34 AM
Zing's Avatar
Wow, cool, thanks. Have you actually heard one? I wonder if it has different horn sounds. WOuld be easy to add as a feature for them I would think.
H2 '04 Black
Old 03-19-2004, 02:10 AM
It is the same sound you hear on firetrucks and EMT units. It is very loud. You can hook it up to you standard horn button. If you hold down the button you get a sustained blast.
This is the same one I have on a full Welen siren unit. It gets the attention of traffic. I use it to clear intersections on emergency runs.
The speaker is easy to mount behind the grill.
Old 03-19-2004, 02:20 AM
CRUZMISL CRUZMISL is offline
CRUZMISL is off the scale
Dick, is this the one you use? Is it that really low, solid "buzz" sound?
Old 03-19-2004, 03:18 AM
If that's it and it is loud... Well that is just what the doctor ordered.
Old 03-19-2004, 02:04 PM
CRUZMISL
That is the speaker and yes it is a low< loud buzz type sound. Called a Klaxton sound. The frequency is designed to cut through most normal sound in a car [radio, fan talking etc.)
KenP
The speaker and airhorn/pa are 100 watt output
which equates to about 135 decibles. The same output as most police and fire sirens. This speaker if located behind the front grill without to much obstruction and facing forward will be very loud. Most police cars use smaller profile speakers and often have them pointed of center and don't get the full output of sound.
I have used Welen sirens and speakers for years and always locate the speaker for maximum sound output. I am always able to get everones attention and get them out of my way. I use this tone on my siren to clear intersections. It even gets the attention of the airheads with the 10 thousand watts of rock blasting in the car.
Old 03-19-2004, 02:08 PM
Dick, so I'll just be able to hook that up to my existing horn wires? The sound of the stock horn is wimpy. I bet that would scare the hell out of most people when you layed it on them
Joe
Old 03-19-2004, 02:12 PM
CRUZMISL
The box has contacts that you wire to your existing horn or you can connect an external button. You hide the box under the dash. You also have the mike for the PA that you hang on the dash. You hook the box to power and ground and you are set.
Old 03-19-2004, 07:12 PM
Oh, I see. I have to buy both items and not just the speaker???
Old 03-19-2004, 08:03 PM
That is correct. The speaker is driven by the horn/pa unit.
Old 03-19-2004, 09:01 PM
So correct me if I'm wrong but the loud horn will cost me over $250?
Old 03-19-2004, 10:24 PM
That would be about right. You can shop around with police supply houses on line or local. Also, you can go to Whelens site and look up local dealers. There site is www.whelen.com
Old 03-20-2004, 02:16 AM
TonkaH2 TonkaH2 is offline
TonkaH2 is off the scale
Has anyone tried the 2 horn electrics they sell at autoparts stores for around 25 bucks? Gotta be better than stock...
yellow H2 adv.
