Old 05-01-2004, 04:01 AM
FrgMstr FrgMstr is offline
FrgMstr is off the scale
First Off, Dry Heat did it FIRST. I just took his idea and adapted it a bit to my own aftermarket brush guard.
I did not want the hi lift inside the truck and I did not want it on top. Dry Heat's idea of solid mounting the hi lift worked out great for me.
Just had to drill a couple of holes as my guard did not have the same mount points. It is extremely solid.
I used aircraft style locking nuts as well to give me some added security. I also used stainless steel wingnuts as I think it makes the wingnuts easier to turn under hard pressure.
Also, the one part of Dry Heat's setup that I could not replicate is the rubber bushings, so we bought a $5 rubber mallet and hacked the ends off of it. Worked out great.
________________________
This place sucks now, bye.
Old 05-01-2004, 04:02 AM
Hi Lift 2
Hi Lift 3
Old 05-01-2004, 04:03 AM
Hi Lift 4
Old 05-02-2004, 01:08 AM
We spent all day today on some very demanding trails at Barnwell Mountain and the mount came through like a champ. Solid as a rock.
Old 06-23-2006, 02:51 AM
dallas007 dallas007 is offline
dallas007 is on a distinguished road
Default Re: Brush Guard Mounted Hi Lift
Can you still open the hood with this set up???
Old 06-23-2006, 03:42 AM
frgmstr isn't around anymore, but if you can't, it's just held on with a couple of wing nuts.
Here's another idea for you, also:
http://www.elcovaforums.com/forums/s...t=hilift+grade
Old 06-23-2006, 04:29 AM
H2Finally's Avatar
Since my original post has gone to the lost thread zone, here's a repeat:
Can BLING Get You Home?
Old 06-23-2006, 04:51 AM
I sure appreciate the prompt and informative response.
Thanks!!
Old 06-23-2006, 05:11 AM
That looks vaguely familiar. Did you do yours before or after me? That's what I thought... COPYCAT!!!!
Hey, shouldn't you be working or something?
Old 06-23-2006, 05:19 AM
H2F, nevermind. You were before me. Now go back to work!!!!11
