  #81
Old 03-01-2006, 04:35 PM
4ophenia 4ophenia is offline
4ophenia is off the scale
Might want to check out Hadley products.
www.hadley-products.com
They list all kinds of compressors and air horns. I picked up the Hadley Bully-Electric Dual Air Horn Kit (code: XXXH00961EA). It's real loud! Dealer installed compressor and horns between grill and radiator. Hooked the horn wires right into steering wheel horn pad. Threw the wimpy factory horn away. Horns are metal so they won't crack in freezing temps. Plus, it comes with an air hose that attaches real easily to compressor through the grill slots. The one I chose is a bit pricey, but I figured with air horn and air hose - it's kinda like a "two-fer".
2006 H3 Adventure/ Yellow/ Ebony/ 5-speed/ Black Brush Guard/ Black Tubular Steps/ Mud Flaps/ Black Crossbows/ Trailer Pkg/ Monsoon/Hadley Chrome Dual Air Horn
Repressed as a child, but no more ....
Old 03-02-2006, 11:33 AM
fourfourto's Avatar
I noticed about midway on frame(outer side) there is a metal plate coming down verticaly with holes for mounting a bracket for the male coupler.It could be mounted straight down and cover it with a rubber cover when not in use so dirt doesnt get in.Easy access to hook up air hose .Its out of the way enough so it doesnt get hung up off roading.Also it wont get in the way if you remove sidesteps for serious offroading.
jp's-h3 whats happening with install? Are you spending to much time in the helicoptor?
Old 03-02-2006, 08:04 PM
jp's-h3 jp's-h3 is offline
YO SUP, FOURFOURTO!
Well I finally got the compressor install finished, I'm going to start a new discussion in this forum (technical), under master flow
mf-1050 air compressor intallation. w/ pics.
I should have it posted by early thursday eve.
have a good one!
Old 03-02-2006, 09:08 PM
fourfourto's Avatar
Thats great I probobly wont install till next week .I have to get the compressor to my brother this weekend and he can bring it in to work.Were going to see if I can change to standard shop fittings that way if original hose goes I can use my 25 foot one I use at the beach.
Old 03-03-2006, 12:32 AM
Keep me posted fourfourto
