09-30-2005, 07:00 PM
Friends:
I'm considering buying a Pull Pal for all the usual reasons. However, I noticed one internet article saying the Pull Pal is intended to assist moving wheels, not anchor a dead weight pull. If that is true, and you are truly stuck, does the Pull Pal make any sense? I must be missing something here and would appreciate members' input.
I've always gotten outstanding advice from you gents and ladies, so I'm asking for more.
Best regards,
George SSSS
Friends:
Best regards,
George SSSS
10-01-2005, 12:10 AM
I got to see and use the Pull Pal RW 11000 frist hand, at the Hummer Driving Academy. We had A H2 SUT all 4 tires buried in sand/dirt, you could open the door and step right out onto the ground, we were stuck.
We hook up to the Pull-Pal, we started to winch and the Pull-Pal set it's self deep into the ground right away, and we winch the rig out of the sand/dirt with no problems.
And the Pull-pal was very easy to remove from the ground, all we did was pull up on the end of the Pull-Pal and it came right out of the ground.
I do have the Pull-Pall RW 11000 for my rig.
Dwayne
Hummer Driving Academy " Graduate "
Class
August, 05
10-01-2005, 10:34 PM
Guys:
Definitely solid information. I'm going to get one. Two questions:
1. When you use it, are you turning the vehicle's wheels?
2. How do you transport yours? I have a Gobi stealth rack on my rig. I saw some brackets on the internet. Do either of you use one of them?
Thanks,
George SSSS
10-02-2005, 01:51 AM
I just carry mine in the back of the Hummer along with my Hi-Lift Jack. Mine is still in the box.
I am thinking of making a mount on the roof basket to hold it.
I read on the net somewere that the Pull-Pal will fit into a gun case bag.
10-02-2005, 02:57 AM
Outstanding. Now I'm all set.
Thanks again,
George SSSS
10-03-2005, 01:48 AM
George
I just bought a Hard Plastic Gun Case, from Wal-Mart for $21.95 .
The Pull-Pal fit perfect in side of it.
10-03-2005, 11:57 PM
Outstanding. Is it a standard rectangular case or something else?
10-04-2005, 02:21 AM
It is a hard rectangular case, it was made to hold two shotguns.
And the Pull-Pal fit it just perfect.
10-04-2005, 03:40 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Arizona Hummerboy:
And the Pull-Pal fit it just perfect. </div></BLOCKQUOTE>
Couldn't find the product on walmart.com but did find this case . Is that about the same thing? Do both parts of the Pull-Pal fit inside?
Thanks much.
\'05 SUT
10-04-2005, 01:11 PM
Here is some pictures of the Case and Case with the Pull-Pal inside of the Case.
The size of the Case is 52"L x 4" D x 11" W
10-04-2005, 01:13 PM
Picture # 2
10-04-2005, 01:15 PM
Picture # 3
10-04-2005, 01:20 PM
The spade part is a projectile waiting to happen and that case is a terrific solution! Thanks for the pics.
\'05 SUT
10-04-2005, 01:28 PM
Now I know what color Hummer to look for on our next Hummer event.
10-04-2005, 01:50 PM
The case works great. The spade was the hard one to try to find a place for in the Hummer.
I removed the top foam from the case, so the top would close better, it was a little tight.
With the case I can now mount it to the Roof Basket, for runs and then remove it after runs.
10-04-2005, 01:56 PM
VernB
My Hummer is easy to find. I have custom window screen on the side. And Awesomesuccess on the front windshild and on the back window.
