Old 06-03-2003, 05:57 PM
Lil Devil Lil Devil is offline
Lil Devil is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by wannabeinit:
devil
Did Xenarc get back to you on the monitor in the headrest question?
Cheers<HR></BLOCKQUOTE>
Xenarc tells me they can be mounted in headrests using enclosures made for this purpose. they did mention that this is probably a professional job depending on your skills in this area. they only pointed out that you need to respect the published operating temperatures for the units. this is critical.
2002 Vette; Vortex Intake, Vortech S/C, Stage II heads, comp cam (220/220/114/.581), 3.90 gears, 14 inch cross drilled rotors, 170 stat, NGK TR6, B&M Ripper Shifter, Autometer Boost & Fuel pressure gauges on a-pillar, Hotchkis Sway Bars, HRE 543 wheels (F:265/35 R:295/35), Z06 titanium exhaust, RK LT headers, Magnaflow x-pipe, Programming by Morgan Motorsports, 5% tint, AA Frame & Rocker Savers, TB Bypass, Lowered 2", Custom Audio;570 RWHP Dyno Here
2003 H2; 37 inch tires, Manik Off-Road pkg., Airaid Intake, Custom Audio
2003 H2; 37 inch BFG\'s, Manik Off-Road pkg., Airaid Intake w/MTI tube, Magnecor wires, Predator Tune, Custom Audio
Old 06-03-2003, 11:28 PM
HappyJack HappyJack is offline
HappyJack is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Lil Devil:
Xenarc tells me they can be mounted in headrests using enclosures made for this purpose. . .
<HR></BLOCKQUOTE>
Does this imply that there are enclosures available for this monitor?
I do have the ability to make the enclosure my self but it would be much better for me if it was an off-the-shelf item!
Cheers
Cheers
Old 06-03-2003, 11:46 PM
I am told there are universal enclosures available that you could use. Unfortunately i do not carry them. I can do some research for you if you want.
Thanks!
Old 06-04-2003, 01:49 AM
Please do find a mount if you can, that would be great! It would be just a plastic shell with a flange, right?
Unless I am missing something, the Xenarc monitor should look better than others I have found due to its high resolution.
Cheers
Cheers
