03-20-2003, 12:17 PM
If anyone has access to scales, I need to know the weight of the H2 per axle. A friend is having an enclosed trailer built with 3 axles, and we need to know where to position the vehicle over the axles. If you pull the front end on the scale, get weight, then do the backend, we would be eternally grateful. Thanks in advance, Gary H2-T2
04-01-2003, 07:14 PM
Coil Spring Rear -> 3550 Front / 2974 Rear
Air Spring Rear -> 3585 Front / 3207 Rear
04-01-2003, 08:05 PM
Thanks, dunrdr. After my orginal post on 3/20, I found truck scales, and weighed the axles. Sent the weights to the trailer manufacturer. Thank you very much for the info. Gary...
04-05-2003, 10:58 AM
I hope u aren't going to HIDE the H2 in a trailer
98 ZR-2 Blazer
Ex H2&3 owner
04-05-2003, 06:40 PM
DURAMAX TIM: No, a friend has a Provost Coach. He likes to travel the country, and is having a trailer built (30 ft.), so when he gets to whatever destination, he can travel in style with his H2. Gary (H2-T2)
