Old 02-03-2005, 05:49 PM
I did my first oil change, and it is a bitch to do w/o making a mini-Valdez on the garage floor. The oil plug drops oil all over the undercarage protector and the oil filter is mounted above the protection plate. Is there a filter relo kit? Is there something I'm missing other than "Do it in someone else's garage"? Guess I was spoiled by my Navigator and its behind the front bumper location.
Want-08 Viper, 06 M5
Old 02-03-2005, 06:04 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Remove your front skid plate, and save yourself the trouble of oil everywhere!
Ric-H2
www.meatspin.com
Old 02-03-2005, 06:33 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> Is there a filter relo kit? <HR></BLOCKQUOTE>
TransDapt p/n 1120
Old 02-03-2005, 07:10 PM
Here is another idea from another member, I just don't remember who:
Use a piece of tin-foil under the drain plug to funnel the oil to the pan and away from the skid plate. he said it worked great and was tried by several other members, all with positive results.
Old 02-03-2005, 07:27 PM
partsguy partsguy is offline
Cut a windshield washer jug down to funnel
the oil to were it needs to go.The shield
does not have to come down,You can still hit
all the grease points with out dropping it.
If your dealer is chargeing you 9 tenths to
change oil your the one getting lubed(or not)
Old 02-03-2005, 07:44 PM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
take it to the deal and for 35 bucks you get a clean h2 and a oil change...........
Old 02-03-2005, 08:00 PM
Every time it gets washed?????
Old 02-03-2005, 08:04 PM
Albie's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by partsguy:
Every time it gets washed????? <HR></BLOCKQUOTE>
12 for 12 for me LA and in Vegas.
Old 02-03-2005, 08:07 PM
Same here as far as the washings go. Hall is great for service.
Old 02-03-2005, 10:13 PM
RIC-H0's Avatar
Here is San Antonio, washes are complimentary.
With or without service.
Just a great part of Ken Batchelors service department!
Ric-H2
www.meatspin.com
Old 02-04-2005, 04:00 PM
Texas Red's Avatar
Texas Red is off the scale
Yep, I usually get mine washed every oil change whether it needs it or not. But I usually push the oil changes out to 5000 miles instead of 3000.
Jim
2008 H3 Graphite Lux
Old 02-06-2005, 01:17 AM
I run synthetic oil and change it at 3K or less, so the 35 buck thing doesn't apply...And I do know that the oil will last longer, I'm just a fanatic with maintenance. Thanks for the relo kit...one is on order.
Old 02-09-2005, 03:41 PM
Dan Dan is offline
That was Zing that suggested the foil trick. I've done it a few times now and there's no mess. Use a small piece to direct the oil from the plug. Then a longer piece up around the back of the filter and down toward your drain pan.
Old 02-14-2005, 01:48 AM
4churchill is off the scale
I tried 1 oilchange, and it just wasnt worth it for me, i strated going to the dealer, for $40 i get an oil change, tires check and filled, and a washing, plus they often will give me an H@ off the lot to run errands in
www.HUMMERNut.net
