Old 04-29-2003, 02:34 AM
AZH2Pilot AZH2Pilot is offline
AZH2Pilot is off the scale
For those who have installed a CB w/ antenna, where did you mount them? I was thinking about going with the all-in-one mic made by Cobra. Nothing showing or taking up room except the cord and mic. For the antenna, I am thinking 4' black fiberglass whip mounted on the right rear bumper. Any suggestions? Thanks.
'03 White Lux H2
\'03 White Lux H2
'03 White Lux H2
\'03 White Lux H2
Old 04-29-2003, 03:24 AM
OLE YLLR OLE YLLR is offline
OLE YLLR is an unknown quantity at this point
I INSTALLED MY COBRA 75 PER "GLENN" ON POST DATED JANUARY 29,2003. WENT VERY SMOOTH. WILL TRY TO POST PICTURES.[IMG]CB INSTALL[/IMG]
Old 04-29-2003, 03:33 AM
<LI>[img]CBINST~1.JPG[/img]
Old 04-29-2003, 03:35 AM
[img]CBINST~2.JPG[/img]
Old 04-29-2003, 03:38 AM
[img]CBINST~3.JPG[/img]
Old 04-29-2003, 04:55 AM
YellowH2-com YellowH2-com is offline
YellowH2-com is off the scale
I also have the Cobra. I really like it. I have dual 4ft fiberglass antennas mounted on my rear bumper just like you were asking about. They really flopped around allot so I had to brace them to my tail light guards. (pictures below)
Inside the bumper is a thick metal plate that will need a very big hole drilled through it to run the antenna cable. It is allot of work but I think the outcome is well worth it.
Regards,
Jerry
Yellowh2.com
Old 04-29-2003, 07:51 PM
SJ SJ is offline
SJ is off the scale
Phil & YellowH2:
You both did clean installs. I'll be taking a few notes from your pages and going to work. I'm still shopping for a base unit, but I've used a Cobra in the past with good results.
________________________
\'03 H2 [Sold]
\'03 Chevrolet Silverado Z71, 6\" Rancho Lift, Rear Factory Locker, 35\" ProComp MTs
http://www.smiliegenerator.de/smiley...miley-9839.png
Old 04-29-2003, 11:45 PM
Hummer Man is off the scale
I want to install a dipole for some skip on USB from Germany. Has anone hooked up any shortwave connections.
Old 04-29-2003, 11:46 PM
What about AMPS???
Old 04-30-2003, 12:37 AM
JohnnyBoy JohnnyBoy is offline
JohnnyBoy is off the scale
I too have the same install as Phil. It works great even with the antenna folded down. Everybody who sees the Cobra75 mounted like in Phil's pic thinks its OEM.
'03 Hummer H2 Adv./Lux. Pkgs. Sunset Orange W/Sunroof
Air Spring Susp. Pkg. + 3rd. row seat & DVD System.
CompuStar Auto Security/Remote Starter.
http://www.haugens.com
\'03 Hummer H2 Adv./Lux. Pkgs. Sunset Orange W/Sunroof
Old 04-30-2003, 02:40 AM
TRYING TO SHOW WHERE COBRA 75 WAS INSTALLED UNDER DASH.
Old 04-30-2003, 02:41 AM
[img]CBINST~2.JPG[/img] HOPE THIS SHOWS WHERE I INSTALLED COBRA 75 UNDERDASH.
Old 04-30-2003, 02:43 AM
CAN'T GET PICTURE TO COME UP!!!!! WILL E-MAIL TO JASON.
Old 04-30-2003, 10:33 AM
Jason's Avatar
Jason Jason is offline
Site Admin
Jason has disabled reputation
Manny's install ...
www.somo.com - Custom. Accessories. Home of the H2 Source and the H3 Source.
Old 04-30-2003, 07:27 PM
Thanks for all of the feedback. I really like the roof rack mount idea. PhilD's and others have very clean installations. I had wanted the bumper mount similar to YellowH2, but, I would not be able to clear the garage. I only have a quarter inch clearance as it is now. I will refer to the past post as guidance.
'03 White Lux H2
\'03 White Lux H2
Old 04-30-2003, 11:57 PM
NCHummerman NCHummerman is offline
NCHummerman is off the scale
For PhilD and those with roof mount antennas... how did you run the wires from the antenna into your truck and get them to the CB unit ??? Did you bring them in through the opening in one of the roof lights, the opening where you can run the wires for the roof lights ?
Michael
Pewter Hummer H2
Northern California
www.zootsuitstore.com
Michael
Pewter Hummer H2
Northern California
Old 05-01-2003, 12:45 AM
YOU REMOVE THE FRONT LEFT RUNNING LIGHT, IT HAS A RUBBER GASKET THAT YOU CAN RUN YOUR COAX THROUGH. FISH IT THROUGH THE FRONT PILLAR INSIDE AND IT WILL END UP UNDER YOUR DASH. FOR ENTIRE INSTALL INSTRUCTIONS SEE GLENN'S POST ON JAN 29,2003
