04-06-2006, 02:18 AM
Does the DriveLine Undercarriage protection from GM just bolt on with no other modifications required????
GM Part # 12498474
04-06-2006, 02:22 AM
Yes.
04-06-2006, 02:25 AM
i had to use a sledge hammer for some moderate adjustment
04-06-2006, 02:26 AM
Originally posted by Sewie:
Yes.
Thanks...
04-06-2006, 02:34 AM
I have a sledge hammer so that shouldn't be a problem
04-06-2006, 02:40 AM
cool chas i had to start with center bolts and beat the trailing end of rear protection up just a little . i had scraped the cross members up pretty good so had to adjust  milk crates help in holding it up close while doing the install . its pretty easy to do even if you have to beat it  have fun
04-06-2006, 02:54 AM
Milk Crates... Thanks... Looks like I'll be heading to the grocery store after work tomorrow...
04-06-2006, 03:19 AM
I didn't have any problems installing mine. Bolted right on, no sledgehammer.
They are pretty light too. I was able to just hold them up to the frame while I put the bolts in. Shouldn't take more than 30-45 mins to install. Much easier than the rails.
04-06-2006, 03:31 AM
Same here. No sledgehammer needed on mine. It was a little bit akward do by myself though. A milk crate would have been perfect. I just put mine on my chest and slide underneath.
Black H3, Adventure Package, Rocker Panel Protectors, Undercarriage Protection
04-06-2006, 05:23 AM
GM Part # 12498474
Normally you just use zip ties for the stock stuff.
04-06-2006, 11:24 AM
We added mine in the parking lot of the hotel when we went to Tellico since I had it shipped there. I can't really tell you if it was easy or not because the guys just climbed under there and started installing, I just handed them tools
Didn't hear any hammering though
04-06-2006, 07:02 PM
Entrestingly enough, not that I'm rich, but lazy didn't have the help/tools needed so had the dealership bolt all my protection on. The cross frame rail that they bolt to didn't have the holes drilled properly, I told them they could probably take a drill and tap the holes but they said it was a defective piece and needed replacing. So it took a couple extra days.
