12-27-2005, 09:09 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by NEOCON1:
just went to big O on my lunch tires 315 70 17 will be there tomorrow but 2 to 3 weeks for my 17x9 chambers  . now i have to get grill line-x'd before wheels arrive  . i will keep you all posted as it progresses  </div></BLOCKQUOTE>
what offset/ backspace did you order?
12-26-2005, 03:40 AM
NEOCON1....
I was playing around with the numbers and this is what I'm figuring. The 17x9's should stick out about 3" farther with the 35's, than the stock rims with 33's. Even with a wider tire & rim, the interior of the 35's will be out about an inch from where the 33's sit now. Rubbing shouldn't be an issue. Looking forward to the pics.
12-22-2005, 06:15 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by BbyHmmr:
I don't think those will fit on the stock rim. I looked at those before I bought mine.
Already been done.
http://elcova.com/groupee/forums/a/t...1/m/8061081051 </div></BLOCKQUOTE>
They're 33's.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">H-Unit
Posted 12-21-05 09:51 AM
I got lucky and the Hummer Logo was on the truck when I bought it! I bought it off their showroom floor and I haven't seen it anywhere else! The tires are basically the stock size, 33x11.5x16
Cheers!
2006 Shadow Green H3
2002 Black/Mod Red Z06 </div></BLOCKQUOTE>
12-23-2005, 04:20 PM
And pictures??????.....
Dallas Stars Green, adventure package, 5 speed, sunroof, xm, mp3,grill guard, tranny guard, rocker guard, rubber mats, GOBI rack, PIAA lights.
01-18-2006, 11:43 AM
OK>>>>>> so basically I have stock suspension adventure package with the 33' tires and stock wheels. I want 35's on my stock wheels. What 35' will fit the best. without rubbing.
and just for curiosity how big can i get the tire on stock wheels without rubbing
thanks guys
Bruce
2006 H3 Yellow
Adventure Package
Onstar
XM Radio
33\' Tires
Stainless Steel Brush Guard
Stainless Steel Side Tubs
LOVE IT.
!993 Corvette Red Pushing 400HP
Perfect Condition.
12-22-2005, 06:48 PM
So answer me this, how did Rough Country fit 37's on stock, but some 35's don't fit? And what brands are P metric ?
Confuses the hell out of me.
12-21-2005, 12:41 AM
I've seen quite a few of you on here with 35's. From what I'm gathering, 315/75/r16's ATs do NOT rub at full lock, but I also read that 35x12.5r18s MTs DO rub. After checking out tire dimensions (315/75/R16 MT vs. AT), it seems 35" MT's are about a 1/2" taller and wider than most AT's. I'm guessing we're limited to 35" All Terrains without modification. Correct me if I'm wrong.
Questions:
1. For those with 35's, what brands are fitting without rubbing? bbyhummer mentioned Mickey Thompsons and Pro Comp Xterrains, but I couldn't find true tire dimensions on these.
Nitto Terra Grappler AT's maybe?
2. The stock 33's kick up dirt all over the rear fender and side. Are the 315/75's 'much' worse? I'm more concerned with regular driving...off road, its something you have to expect.
3. Stock chrome rims are the same dimension, but the dealer swears they can't hold the same tire as adv. pkg wheel. Why, I don't know. Will 35's fit stock chrome wheel? 8" seems to be the minimum wheel width required for 35's, but I'm seeing 37s on stock rims  It's confusing.
4. Power - Is there a noticeable difference in power? Sticking to a lighter stock rim, I'd imagine it wouldn't be too noticeable.
5. Torsion bars - How many turns, if any, do you recommend?
Kacyk answered a lot of these questions in a past thread, but he had MT's and a heavier 18" rim. I wanted to gather info on 35's on stock rim.
12-21-2005, 01:13 AM
It's only a 1/2", I'm sure the tire companies are playing it safe for liability purposes when it comes to wheel recommendations.
12-24-2005, 10:17 PM
Cool, glad it worked out even though you had to take one for the team. If your ever down this way the beer is on me. Would love to see some pic's when you get time, maybe front, rear and side shots?
12-21-2005, 12:56 AM
I am in the process of doing the same thing. The Rancho lift is coming off on Thursay and they are putting the 35/ 12.50 Procomp Extreme AT's on the stock rims. they told me that the 35's should be fine on the 7.5" rim. The tire manufacts. suggest 8". but we'll see.
12-26-2005, 01:16 AM
the wheels i wanted wont fit in a 16 so now thinking 17's with these http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf in a 315 70 r17 they measure 34.5" overall the wheels are 17 x 9 with 4.5" bs offset is -12 how will these work thanks </div></BLOCKQUOTE>
They will stick waaaaaaayyyyyy out! If you go look at my post inthe photos section with the lift, those were 4.5" of backspace. I hated it so bad becasue you drive through on puddle or rain/ snow and your rig is trashed! If that's the look you want, great, it looks good. But as a daily driver, I am happy they are back in!
12-22-2005, 03:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Already been done. </div></BLOCKQUOTE>
I think those are 33's
12-22-2005, 03:58 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by The Green Lantern:
I am in the process of doing the same thing. The Rancho lift is coming off on Thursay and they are putting the 35/ 12.50 Procomp Extreme AT's on the stock rims. they told me that the 35's should be fine on the 7.5" rim. The tire manufacts. suggest 8". but we'll see. </div></BLOCKQUOTE>
I'm planning to put this on my stock rims - LT35 x 12.5 R16. </div></BLOCKQUOTE>
I don't think those will fit on the stock rim. I looked at those before I bought mine. </div></BLOCKQUOTE>
Isn't the 35 x 12.50 x 16 the same as 315 75R 16?
12-23-2005, 08:12 PM
... still waiting. I pick it up later today/ I hope! I will post some pics too.
12-22-2005, 02:35 PM
Already been done.
12-26-2005, 01:32 AM
Neocon, which wheels were you looking at?
12-22-2005, 12:37 PM
06 Hummer H3
Boulder Gray
Adventure Package
35\" ProComp Xterrain
12-24-2005, 01:51 AM
YEAH! They fit. They touch the sway bar just a tad. My torsion bars are at the stock height too. So for those that are questioning if they fit, they do! I went from 35's to 37's on my SUT and had way more rubbing than this. They barely touch and that's at full lock in reverse only. I'll post some pics in a day or two if anyone still wants some.
Now all I have to do is order a new front skidplate. They cut mine to make it fit for the Rancho Sucko lift.  So, other than that, it rides just like it did two weeks ago when I picked it up from the dealer.
12-25-2005, 03:22 PM
12-23-2005, 02:45 PM
so.....did they fit?
Hybrid Mode
