Old 02-09-2006, 05:35 PM
Forgot to say that I'll give you the answer tonight.
Old 02-10-2006, 11:04 AM
Easy Ed Easy Ed is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">It took me two days to find the problem. Let's see if you can do better. </div></BLOCKQUOTE>
Would have taken five minutes to figure that out while actually driving it around versus the misleading discription given <BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> Please remember we're talking about BigNasty with big tires and a lift. </div></BLOCKQUOTE>
I just wonder what the folks driving behind you thought while watching it happening, damn is that big tire going to come loose and hurt us.
Old 02-10-2006, 02:44 AM
Dewi2005's Avatar
Dewi2005 Dewi2005 is offline
Dewi2005 is off the scale
rear u-joint... my guess!
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
Old 02-10-2006, 04:21 AM
Notice CP didn't respond here.
Old 02-10-2006, 09:34 AM
NO, NO, NO!!!! Damn you all. Let's get things working...
Here's the answer that took me two days to figure out... Without your help because you all suck!!!!!!
The rear tire carrier was not fully closed, thus the lock was not engaged. Hit the gas and the tire swings out and catches the safety cable. Slow down and the tire rack BANGS back into place. You all bring the suck!!!
Sheeze..... Good thing I know my sheat. </div></BLOCKQUOTE>
AND IT TOOK YOU TWO DAYS TO FIGURE THAT OUT????
Mark
Old 02-09-2006, 10:09 PM
Assuming we're not talking about lugs on a tire....
I'm going to say that you either have a ujoint problem or an incorrect pinion angle. Hitting the brakes will unload the rear end and hitting the gas will give a shudder if the pinion angle is off when you torque the rearend.
Nonetheless, I'm guessing something in the drivetrain. Ujoint, driveshaft, etc ,etc..
What's the answer?
Mark
Old 02-10-2006, 12:30 AM
Klaus's Avatar
Klaus Klaus is offline
lack of supercharger
</div></BLOCKQUOTE>
Old 02-10-2006, 12:33 PM
Dan Dan is offline
I was going to say the tire carrier.
Old 02-10-2006, 12:56 PM
It\'s a Dry Heat's Avatar
PhilD is trying to trick us into thinking he got it. Look at the Edit date.
Old 02-10-2006, 02:48 AM
H2Finally's Avatar
Loose wheel?
Can BLING Get You Home?
Old 02-10-2006, 12:44 PM
I was going to say the tire carrier. </div></BLOCKQUOTE>I would have said tire carrier but I didn't want to let on that I've done the same thing. Except it was the wife's fault, she didn't latch the carrier.
Old 02-10-2006, 07:09 AM
HummBob's Avatar
HummBob HummBob is offline
OH
You see, this NEVER WOULD HAPPEN ON A BLACK H2, that's why I couldn't figure it out
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 02-11-2006, 12:34 AM
H2Finally's Avatar
Congrats to the winner PhilD!!!
You won a $250 gift certificate from Trail Duty. Spend it wisely. </div></BLOCKQUOTE> </div></BLOCKQUOTE>X2
