08-03-2005, 10:44 AM
Sorry I was working and trying to answer you at the same time.
I didn't know the factory backspacing
If 5.5 is correct and you switch to 4.25 instead of the usual 4.5 that would bring the tire in closer to the frame a 1/4", probably still rub with the 13.5 tires.
Also every Hummer is a little different some rub more than others with the 37 x 12.5 tire and 4.5 spacing. 4.25 would help that.
I guess you just have to go to the tire store and test fit...
Good Luck
08-28-2005, 07:30 PM
hey drty shoot me a pm.. i wanted to know if you wanted to drop any of your 37's i think i need a set for this winter.. time to upgrade from the at's.. hope all is well.. hit me up
- DH22G
David
2007 Acura TL Type S
08-02-2005, 05:40 PM
The MG's will be loud. I have the TG's and they're louder than stock, but not so bad.
07-28-2005, 04:42 AM
J/K!  Great comparo. You sure they're same size? The Toyos quieter though huh?... hmm... anyone need a set of BRAND NEW MTRs???  </div></BLOCKQUOTE>
They're VERY quiet. I'll be off-roading in the next couple of days to try them out. Stay tuned for the review.
07-28-2005, 04:59 AM
I'll check tomorrow. But the Iroks are super tall.
I went with the 35's because the 37's only come in a 13.50 width and those would rub like Oprah's thighs rushing to a buffet. </div></BLOCKQUOTE>
Cross posting, we are. Thanks!
\'05 SUT
08-08-2005, 04:22 PM
Doc,
I ran out to Brown's Camp last week and tried them out on Hog's Back. Usually I need to reposition once when going up HB, but with the Toyos I walked right up and never even slipped a tire.
08-01-2005, 10:00 PM
drty THAT LOOKS SICK MAN.. i know those toyos are awesome tires. let me know how they are offroad.. i saw a lifted silverado hd in BIGBEAR this weekend and it was a toyo mt 40 /13.5/22 . I was about to shoot fireworks in my pants it looked so amazing... still waiting for mine over here ,,,
- DH22G
David
08-23-2005, 09:46 PM
no idea on actual rim size, i'd have to ask les schwaab. i just wanted to get rid of the chrome diamos that were on it when i bought it, and go back to 17" from 18"
08-02-2005, 07:49 PM
Yes it will rub with the 4.5" offset, the only way you can get 37 x 13.5 tires to fit is to use the factory wheels. I'm sure the offset on factory wheel is less than that.
08-02-2005, 06:32 PM
Rodster
if you go with the 9.5 rims it WILL rub on the inner fender and front stabilizer bar. I was able to put the 13.5 tires on only because I kept the stock 8" rims with the factory off set. Do not try this with after market rims. Unless your never going off raod!!!
Thanks, Jerry. That's all good news. I have the Fabtech steering components sitting here in boxes and plan to have those installed when the tires and wheels go on.
The big challenge right now is the tires -- nobody I've talked to has Toyos. Any tips on that?
I'm leaning toward American Racing Mojave Teflons 18x9.5 with Toyo M/Ts 37x13.50x18. Anyone have thoughts on that combo?
If I can't get the Toyos soon then I may very well go with the same size tire in the Nitto MG. Then, when the Toyos are finally available, if the Nitto noise is making me nuts, buy the Toyos.
Thanks again -- Rod </div></BLOCKQUOTE>
07-28-2005, 04:14 AM
I couldn't stand it any longer. I had to try these new Toyo MTs. As most of you know I'm a bit of a tire packrat. I've got a set of brand new stock BFG ATs on stock wheels, a set of 37x12.50x17 Iroks on black stock wheels, a set of siped stock BFG ATs w/o wheels and a set of 37x12.50x17 MTRs on black wheels. The MTRs were getting down to the 50-60% tread range so I figured it was time to try some new tires(in anticipation of the next Moab trip  ). I've been hearing great reviews on the Toyos so I called up my local Les Schwab store and ordered a set.
I was surprised to see that the 35" Toyo was as tall as(if not slightly taller)the 37" GY MTR. The Toyo also looks wider because of the tread design and sturdier outer lugs. The Toyos look more aggressive than the MTRs, but ride as quietly as the stock BFG ATs. Directional stability is much improved over the 37" Iroks and a bit better than the MTRs.
I took the following pictures to show the flex of an aired down Toyo MT vs a GY MTR. Both were aired down to 15.5psi.
08-01-2005, 01:53 AM
Depending on the terrain any where from 18 down to 12. !2 is for maximum traction and I usually air back up 3-4psi.
You'll like the 37" ATs. I spoke with a guy that had them and he liked them.
(As you can see I've been procrastinating on getting an Irok off the stack to measure. I'll get to it... eventually.  )
07-28-2005, 04:16 AM
MTR @ 15.5 psi.
07-28-2005, 04:57 AM
Think I just answered one of my own questions. Looking at Toyo's website it doesn't look like the 37s will fit a stock 17 rim?
\'05 SUT
08-08-2005, 02:54 PM
Was there a final word on off-road performance? How do they do in soft dirt? We have an abundance out here...
If they're about the same noise level on the highway as stock, I think i've found me next tires....
'03 H2
08-02-2005, 04:58 PM
Thanks again -- Rod
\'05 SUT
08-06-2005, 04:16 PM
I've had these on my wife's H2 for some time now and she loves them. No need to air them down going over the Bellevue Mall speed bumps!
2003 Yellow H2 LUX (Sold)
08-04-2005, 03:11 AM
i have heard that they are awesome compared to the stock ats. because they are so soft.. toyo has been a sponsor of my other rides for a long time and they are usually pretty honest with me
- DH22G
David
08-23-2005, 04:51 PM
Drty, are those the black HID lights? If so can you post what brand or where you got them. They look similar to these.
08-01-2005, 07:10 PM
I'm a tire pack rat and I like variety.
Hybrid Mode
