Old 02-01-2009, 09:42 PM
H2ummer H2ummer is offline
H2ummer is an unknown quantity at this point
Default SUT Tonneau Cover Install Instructions and Photos
I decided to put the Tonneau Cover (PN 12499433) on my SUT even though many had said "Take it to the dealer".
I ran into one issue and diverted from the Instructions. I thought it would be a better job than the way they said to to do. This involves installing some weatherproofing behind the Sail panels (See Do First 1). They have you pull back the Sails at the bottom, and try to work blindly with just your fingertips. So I just removed the Sails and put the weatherproofing on while the parts were in my lap. Below are the instructions followed by some install photos. It took me 4-5 hours to put it on, but could do another one much quicker, after learning what I was doing. I have been pleased with the outcome.
I purchased the Tonneau Cover from an Online dealer for right at $1,000 delivered to my doorstep. Shipping costs a bit, as it is about the size of a twin size mattress while it is in the box. The Retainer Clips (PN 11588882), that are needed if you pull the Sail Panel completely off I also got online for about $50 delivered.
Here are the instructions:
Do First 1 Do First 2 Install 1 Install 2 Install 3 Install 4 Install 5 Install 6
The Photos right after the break.
03 H2 Pewter W/Lux, with 05 Navigation Radio and XM added. (Sold)
07 H3 Slate Blue W/Lux, Off-Road, NAV, Sunroof, XM, Tow, Auto (Sold)
08 H2 White W/Lux, NAV, Air Sup.
Old 02-01-2009, 09:57 PM
Default Re: SUT Tonneau Cover Install Instructions and Photos
Ok, Here are the Photos starting with a shot of the bed without it.
Remove the Torx Screw.
At this point the instructions have you pull the Sail back and install the weatherproofing. See Do First 1. If you do as I did, you will need to remove the top Torx and Marker Light.
Remove Light.
Remove light mount.
Move the Light and mount out of the way so you can take the Sail Panel off.
Pull Sail Panel Back. If you move it back very far it will break the retainer clips. I went ahead and removed it so I broke all 7 retainer clips and replaced them with new ones that I had ordered.
Old 02-01-2009, 10:19 PM
Here is one of the broken retainer clips.
Sail Panel removed and retainer clip holes exposed.
Backside of the Sail Panel with new 3M Tape and new Retainer Clips installed. Also the weatherproofing has been installed. Very easy to install the weatherproofing with it off.
Sail Panel in position to POP in using the new clips.
The Driver side with the Sail Panel removed and the broke retainer clips exposed.
Rail - Panel Brackets being laid out.
Panel Brackets Mounted to Rail.
Hatch Pin mounted to Rail
Install Rail pieces to both sides and set Cover in place. Then tighten the 6 bolts and nuts holding it down.
Install the Hydraulic Shocks
More to come after the break.
Old 02-01-2009, 10:25 PM
Here is the Tailgate Latch Stop.
Hatch Pin Installed.
Cover Catch/Release
Vertical Seal (Installed earlier)
Other Vertical Seal
More To Come After the Break.
Old 02-01-2009, 10:29 PM
All Done shown with Cover up.
Another completed shot.
Last One.
Old 02-02-2009, 01:00 AM
Intercooled's Avatar
Intercooled is off the scale
Great tutorial! I already had mine when I bought my H2 but I will book mark this for future trouble shooting. Nice job! Now go get a GOBI bed rack!
2006 H2 SUT Fusion Orange LE
Old 03-20-2012, 07:20 PM
pjensen pjensen is offline
pjensen is on a distinguished road
Anyone still have these pictures and or instructions?? If so, please email to me at pjensen@copter.com
Old 03-21-2012, 01:55 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Better yet it would be better to post them back on this thread for everyone to see. I would love to see those instructions.
Old 02-08-2014, 05:03 PM
STL Zombie Hunter's Avatar
STL Zombie Hunter STL Zombie Hunter is offline
STL Zombie Hunter is on a distinguished road
+1
Keeping St. Louis Zombie-free since 2008
1984 M923A1 5 ton 6x6 Cargo
2006 H2 SUT Twilight Maroon SOLD
2004 H2 Hummer Black SOLD
(5) 37 x 12.50 R16.5 Goodyear MT/R Kevlar lined
HMMWV 24 bolt 2 piece wheels
Hutchinson VFI Anti-Mine runflats
Road Rhino 1/4" steel bumper
1972 Corvette Stingray
Built in St. Louis Day 1, car #75 off assembly line
2013 Infiniti G37X
wife's car
Old 02-09-2014, 12:08 AM
fyr145's Avatar
fyr145 fyr145 is offline
Moderator
im not seeing any photos at all.
Old 02-10-2014, 03:57 PM
Instructions can be downloaded here. https://www.dropbox.com/s/7z6x13te7z...ll%20Scans.zip
I can put the photos up there too, if someone needs them.
H2ummer
Wendell
Old 01-13-2017, 04:03 AM
clsimmon clsimmon is offline
clsimmon is on a distinguished road
Does anyone have a copy of the instructions for installing the SUT tonneau cover? All of these links in this thread appear to be dead.
Copyright ©2000 - 2024, Jelsoft Enterprises Ltd.
