01-13-2009, 09:08 PM
Shifter lock wiring diagram for connector
Can anyone help me? I have the issue where you can't get your key out of the ignition. When I removed the center console cover and low and behold I had a cut wire on the shifter lockout harness. When I tried to pull the connector out I pulled out some of the wires and now do not know where they go in the connector in in what order. There are 5 wires...red, yellow, blk, green/wht and green/blk. The connector has each slot labled with A, B, C, D, E and F.
Help!!
01-14-2009, 08:13 PM
Re: Shifter lock wiring diagram for connector
Pin
Wire Color
Circuit No.
Function
A
BLK
1050
Ground
B
LT GRN /BLK
584
Park Lock Control Solenoid Supply Voltage
C
YEL
1996
Remote Shift Selector Signal
D
Not Used
E
DK GRN /WHT
1135
A/T Shift Lock Control Solenoid Supply Voltage
F
PNK
1020
Ignition 0 Voltage
01-14-2009, 11:11 PM
perfect! Thanks!!
01-14-2009, 11:31 PM
Hey HUMTECH,
I appreciate the info!! Also have another related question:
I replaced my ignition switch today, as I was getting an engine light as well as not being able to get the truck out of park and according to some other threads this may be the result of a bad ignition switch, which may have been compromised by my messing all of the harness wires you gave me the line up for. When I took the old switch out I unplugged the wires from the bottom of the switch and from the top of the Key Unit which I am now figuring out was a NO NO! Well....all the lights come on the dash but the ignition doesn't turn the motor over. I believe I am appearing to the truck as a thief. Is there a way to reset this or am I missing something?
Thanks!
01-15-2009, 01:31 AM
the switch is adjustable. the plastic gear on top needs to be adjusted to the same position as the one you removed
01-15-2009, 06:05 AM
That worked to get it started now it just has the engine light on still and is stuck in park.
01-16-2009, 02:40 AM
Ok....so now I have had all of the codes removed and and everything is working correctly but it won't come out of park without manually pressing release on shift actuator. I have replaced Ignition Switch, Brake Light Switch and checked or replaced all related fuses that I know about. Still can't get out of park. I put a multi switch on the Green wires that relate to the brake release both at the brake pedal and at the actuator on the gear shift and neither produce any current when brake is off or on.
I am lost...
01-16-2009, 11:36 PM
Sounds like you need the shifter assembly. I dont think you can get the shift lock actuator without the entire shifter.
11-21-2015, 08:00 PM
I realize this was a while back, any outcome on this issue that took place?
2003 h2
6" Fabtec lift
18x9 ultra wheels
37" Mickey Thompson mtz
2005 h2
Blacked out
Procharger Dsc1 supercharger
JBA headers/Exhaust system
20x10 ultra wheels
