Old 10-18-2006, 06:24 PM
ree's Avatar
ree ree is offline
Default How much grease?
So how much grease should you pump in all the fittings on the front end? I assume you don't want to add so much that the rubber boots balloon up a lot.
'03 pewter base H2
Old 10-18-2006, 06:30 PM
Default Re: How much grease?
yes
Old 10-18-2006, 06:39 PM
ree's Avatar
ree ree is offline
Originally Posted by PARAGON
yes
You're informational posting quotient is so going up because of that. Thanks.
'03 pewter base H2
Old 10-18-2006, 06:42 PM
Just here to help.
Old 10-18-2006, 08:59 PM
ree's Avatar
ree ree is offline
Am I going to have to pull a tomp and put Phil's name in the subject?
Or do we have some real mechanics on here wasting their day away reading the forums?
'03 pewter base H2
Old 10-18-2006, 09:10 PM
You answered your own question and I confirmed it for you.
There is no "amount" to quantify. It would differ for every part and each time you lube it.
Don't you live in the cornbelt? Get a farmer to help you.
Old 10-18-2006, 09:39 PM
ree's Avatar
ree ree is offline
If that means add just enough to make the rubber boot start to move, but no more, I'll accept a yes.
That would involve going out in the chill and actually talking to someone.
'03 pewter base H2
Old 10-18-2006, 09:44 PM
CHILL?
I can't even imagine what chill might feel like. It's like 85 degrees here.
But, yeah, get some in there, but don't overfill so it's deforming the dust cover.
Now, are you going to get out into the chill to lube it?
Old 10-18-2006, 09:45 PM
mdoyle mdoyle is offline
mdoyle is on a distinguished road
If you're going to grease it yourself it's very important to buy the right type of grease- they aren't all the same and various formulations can't be mixed.
You will see movement in the rubber boots as new grease is added but you shouldn't add so much that you dislodge the boot or over pressurize it.
Grease guns are different but if I had to guess I'd say usually 4 or 5 pumps on a large gun is sufficient. More or less depending on how long it's been since they were greased.
Old 10-18-2006, 09:51 PM
ree's Avatar
ree ree is offline
CHILL?
35, overcast, drizzling, and windy.
Nope. Heated garage. At least 50 degrees.
'03 pewter base H2
Old 10-18-2006, 09:52 PM
ree's Avatar
ree ree is offline
I've got a NLGI #2 Cat LB. Per Phil's recommendation in this thread (I actually do try to look stuff up before asking).
'03 pewter base H2
