Old 10-08-2007, 12:25 AM
DrG DrG is offline
DrG is off the scale
Default Tie Rod End Grease Seal
After changing my oil, I shot a little grease into the zerts and noticed that I was have a small stream of grease coming out right in the middle of the rubber seal on the passenger side tie rod end. I am not saying it was losing grease at the upper or lower edge as when you overfill it, but this is a tiny hole in the center of the seal. I could reach up there and push on the rubber and more would come out. Is this a leak or is there an overflow valve in these? I didn't see this on the other side and of course, I turned 36000 miles last month too.
2005 H2 Adventure, Nav, Sunroof
Old 10-08-2007, 04:39 AM
vlxjim's Avatar
vlxjim vlxjim is offline
vlxjim is on a distinguished road
Default Re: Tie Rod End Grease Seal
Not a problem there made to do that your just pushing out the old stuff.
06 H2 Limited SUV Pacific Blue
Old 10-08-2007, 05:17 AM
DrG DrG is offline
OK, I have seen it push the excess out the top edge and/or bottom edge but haven't ever seen it push it out from the dead center of the rubber resevoir deal there. It is as if there is a hole in the middle of the barrier that holds the grease in place.
Old 10-08-2007, 07:36 AM
tower's Avatar
tower tower is offline
Just FYI, those are ZERK fittings. Zerts are breath mints.
Old 10-08-2007, 06:24 PM
IRA51's Avatar
IRA51 IRA51 is offline
sounds like a good time to upgrade to the Fabtec tie rods .
A government big enough to
you have.
-- Thomas Jefferson
Old 10-09-2007, 05:25 AM
DrG DrG is offline
Thanks for the info. I'll remember to use the Zerts before greasing the zerks.
Old 10-09-2007, 05:31 AM
DrG DrG is offline
Sounds like a plan to me.
