06-09-2007, 03:19 AM
Undercarriage Rust Solution Options
Well I brought home my SUT this week. I have spent the last few nights detailing the interior and exterior. My truck sat on the Hummer lot for about 3 months and shows a lot of surface rust on the undercarriage and frame. I have searched this forum and spoke to the dealership.
What are my options? I have searched the forum and found a few options and the dealer suggested rustolem.
had '05 H2 SUT, LUX, Desert Sand
Had '05 Desert Sand H2 LUX
Had '05 Red Metallic H2 ADV
06-09-2007, 03:23 AM
Re: Undercarriage Rust Solution Options
It gives it character.
06-09-2007, 03:54 PM
RUST,WHAT RUST ? Here in the desert if you let it sit too long unused all you get is Black widdow's and thier web's .
A government big enough to
you have.
-- Thomas Jefferson
06-09-2007, 04:46 PM
What I did was acquired a wire brush, brushed the exposed pieces. If the parts were painted, I first sprayed with paint remover, let sit for about 5 hours, then brushed off. After that I washed it, and dired throughly, then applied primer. I let that sit for about 2 hours, then sprayed again. After about another 4 hours, I sprayed with black barbecue grill paint (the stuff that is high heat rated). After 2 coats of that, I ten applied several coats of clear lacquer to seal it up. I know it sounds like alot, but I also did my truck before the H2 like tis, and it (undercariage) looked new when I sold it. Just my .02 Jamie
06-09-2007, 11:22 PM
Ospho is your friend...
06-10-2007, 12:15 AM
Rattle Can Rustoleum!!! Worked well for me!!
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
06-10-2007, 01:05 AM
I never heard of that. What is it?
06-10-2007, 04:41 AM
http://www.ospho.com/
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
06-10-2007, 04:44 AM
Originally Posted by HummBob
That stuff seem kinda expensive. Didn't read the whole MSDS sheet, but from what I did, seem to be good stuff. Thanks bro.....Jamie
Hybrid Mode
