Old 10-12-2008, 02:00 PM
CBR_Raven's Avatar
CBR_Raven CBR_Raven is offline
CBR_Raven is off the scale
Default problem...H2 stalling
does anyone know if i need to replace a sensor or if i have a more serious problem? my H2 runs rough at idle and goes up and down from 400rpm to 600rpm. it even stalls sometimes at takeoff
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
Old 10-13-2008, 05:18 PM
CBR_Raven's Avatar
Default Re: problem...H2 stalling
just drove the H2 again and it seems that it only does it when the truck is in gear...it actually idles just fine as long as the truck is sitting in park but once i shift into any gear, it seems to drop in RPMs and feels like it's going to stall until i give it gas...once the truck is going, everything seems normal.
2018 Polaris GEM e4
Old 10-14-2008, 05:29 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Does it happen with engine cold? hot? SES light on?
Old 10-14-2008, 10:49 AM
CBR_Raven's Avatar
it happens cold and hot...there's no light on
2018 Polaris GEM e4
Old 10-14-2008, 07:00 PM
8500lbs's Avatar
8500lbs 8500lbs is offline
8500lbs is on a distinguished road
How many miles, My thought are maybe spark plug wires or maybe plugs themselves. My other thought is that the Throttle positioning sensor could be faulty, and my final thought is that the ECU I belive controls the rpm at idle and if you have a new ECU or new programmer hooked up to the car it could have changed the Idle RPM. Mine will also idle around 600 rpm and when cold will sometimes run choppy and drop to 400 but I belive it is a big part because of wires and plugs. I am at 88,888 miles!
B
Old 10-14-2008, 07:53 PM
CBR_Raven's Avatar
B
It has about 68,000 miles on it...i"m thinking throttle position sensor as well. however, i drove it again last night and it seemed to be fine with no problems...i'm going to clean the MAF sensor one more time and clean my air filter today and see what it does after that.
2018 Polaris GEM e4
