Old 06-27-2014, 06:16 PM
ingydrummer ingydrummer is offline
ingydrummer is on a distinguished road
Default HELP! Can't get key to turn to remove ignition switch
I took everything apart to reveal the ignition switch, but nothing Im doing is letting me turn the key to remove the ignition cylinder? Im screwed..
Old 07-01-2014, 07:21 PM
Hellz Hellz is offline
Default Re: HELP! Can't get key to turn to remove ignition switch
well, there are a few threadss about the ignition key issue... im sure a simple seearch would pull them up...
ill help you out and narrow your choices down.
1. call a tow and have your H2 towed to a dealer who will replace your ignition switch, and charge alot of $$$
2. search this forum for ignition switch issues and see the pics. get a drill and drill through the plastic and use the drill bit, or something else that can rach the ignition key button release to get your key out.
bottom line, you will need to replace your ignition switch, unless you keep doing step #2 to press the button to release the key.
Old 07-02-2014, 02:02 PM
H2Miami's Avatar
H2Miami H2Miami is offline
H2Miami is on a distinguished road
Happens to me me . usually moving/push the shift stick forward and sideways solve the issue
Old 07-02-2014, 07:51 PM
guruerror's Avatar
Agreed...happened to me before too due to the shifter. I was able to get it to release the key by shifting back to Drive and then back to Park.
Could be the ignition switch or the 'linkage' (whatever it is) that tells the ignition that the tranny's in Park.
CNTRY
DTOM
Old 07-03-2014, 12:46 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Those are all issues with not being able to turn cylinder back to the off position. From what I understand ingydrummer is not having this problem. The ignition cylinder is in the off/lock position and wont rotate forward to the on start or run positions. Only reason for this to happen would be a damaged key or a lock cylinder that has come apart internally.
1998 Chev Z71
2007 Chev Trailblazer SS
Old 07-06-2014, 04:31 AM
H2Miami's Avatar
"turn the key to remove the ignition cylinder? "
Or you meant turn ignition to remove the key?
