01-08-2007, 02:38 PM
Re: upgrading battery
Originally Posted by Lex_Ordo
24 volt, hmm?
Like a GI Humvee.
12 volt dual battery
01-08-2007, 03:51 PM
yeah.. 12vdc w/ 1630 cranking amps... ARGH ARGH ARGH...!!!!
04-01-2008, 07:57 PM
My battery died again and I pulled it. There is no way I am going to replace it with something as small as what was in there...
Searched this thread up. Anyone recall how Paragon got 2 in his rig?
Did he stack one on top of his fuse bay?
04-01-2008, 09:50 PM
Paragon had an H2. Now that the aussies have 3's to play with, they are trying to fit two batteries in there too.
04-02-2008, 11:16 AM
So now my question would be do you go with the red top or the yellow top if you are running off road lights and a winch in the future.
04-02-2008, 04:26 PM
I went with the red top.
Why?
My H2 doesn't have a big stereo and I don't ever plan on running my lights or winch without the engine running.
07-21-2008, 07:12 PM
I'd like a new battery too. Optima battery, but which one is better yellow or red and are you saying they dont fit in the hummer's cooling box without modifying it first?
07-22-2008, 12:44 AM
Best thing to do is discard that box and get a good rv deep cycle that fits the tray under the plastic box and go with that...
07-23-2008, 03:44 PM
I did some battery research.
As I understand it:
The Optima batteries are virtually indestructable, super-powered, long-lasting fast-charging, cutting edge spiral cell technology automotive batteries. The closest competitor using the same technology(spiral/leakproof/antivibration/etc) is Exide Tech's Select Orbital battery.
Exide batteries
The Exide battery is a Select Orbital and has 690CCA, 850CA and for the H3 the model# is ORB75DT-84. The dimensions are L 9-1/16" W 6-7/8" H 8-13/16
Lowest online price found was $114.95+shipping $20.00+ depending where you live @ remybattery.com
Optima Batteries
The Red Top battery is an SLI (starting, lights and ignition) battery to be used solely for starting applications.
The redtop that comes closest to fitting the H3 is Model 25 Size Category: Med-Small L9.25 x W6.3 x H7.7" Height includes 1" terminals It features 720CCA and 910CA Lowest online price found was $149.95 w/free shipping @1st-optima-batteries.com
The Yellow Top battery is a deep cycle battery for traction applications, such as winches, wheelchairs and similar electrical vehicles or for heavy duty starting of engines with a higher drain on the battery.
The yellowtop that comes closest to fitting the H3 is Model D75/25 Size Category: Med-Small L9.25 x W6.7 x H7.8" Height includes 1" terminals It features 650CCA and 810CA Lowest online price found was $172.95 w/free shipping @1st-optima-batteries.com
The Blue Top battery is a combination starter and deep cycle battery specially adapted for the marine environment.
So Red is Basic everyday daily driver use
Yellow is for offroaders/customzers with winches, lightbars, mega-amped sound systems that wanna run things with the engine off
Blue is if youre converting your H3 into a sealed submersible vehicle and are planning to storm the shores of some distant foreign land.
In the end...
The Exide battery with slightly lower amps may be the better bet as far as Price, Fit & Finish go
The Optima's if you want the added power, but be prepared to retro-fit your cooling box to make it work/look good.
08-31-2008, 01:57 PM
What is the warrenty on the original battery? (can't find my book)
This morning wouldn't start, got a jump and all ok...went to breakfast and after, it started but with a little ump...!!!
ABS light came on, Traction Control light came on, A/C stopped working....got home Ok, just a little warm with no A/C, called ONSTAR, the sweet young thing had to pass me off to a TECH who said:
it could be the battery
it could be a short in a wiring harness
it could be the alt
it could be a computer problem
it could be a combination of problems
it could be a could be...
If I knew for sure the battery is not covered I would pull it and just get a ride to AUTOZONE or PEPBOYS or NAPA or SEARS or SUPER WALMART or somewhere, have it checked and
WAM BAM THANK YOU MAMe !!!
Any ideas, I have around 35000 miles, very very little off road, no winch, no moon roof, no frig ...etc
only have my OOOGAH HORN and the trailer package (but no trailer)
08-31-2008, 06:34 PM
RYD,
Your best bet is to go to Costco and get a RV battery to replace what you have. Even if your battery was coverd after prorate and dealer BS you will be better of changing it out...
You will need to get rid of that plastic housing so a decent battery will fit in the tray. Since I did mine no problems.
08-31-2008, 06:45 PM
Originally Posted by wpage
RYD,
Thanks...
I read a lot in the SEARCH but can't find the warrenty period...
Also it could be a lot of different things according to their tech...can't remember my battery going bad in other cars in that short a time, 35000 miles, little over 2 1/2 years...
its not so much the money but the inconvience...read about the optima batteries, YELLOW, RED & BLUE---with my rheumatoid arthritics modifing the area the battery sits in is difficult...
Do you have any other suggestions or does anyone else?
08-31-2008, 07:35 PM
Just went outside to see if she starts and was going to empty her so I can take into the shop tuesday morning
and
of course it started raining again, been raining lots today because of Hurricane Gustav...
anyway
it started but not happily, the A/C not working good and the phone has a background whistle...
but
the ABS light and the traction light did not stay on...while talking on the car phone all of a sudden the A/C starts working normal, checked the windshield wipers and now they work at normal speed, the noise disappeared from the phone, i turned it off and restarted several times and it was as if all was normal...
I DON'T TRUST THE BASTARD......!!!!!!!!
as soon as it stops raining I'll empty it from all my junk...the weather has cooled maybe 8 degrees and i'm thinking I might have a short somewhere, when the temp is hot it expands and maybe there is an open circuit and as it cools things return to normal...
someone suggested I take the battery connects off, clean the posts and reinstall so i'm going to try that also...
comments !!!!!!!!!!!!!!!!!
08-31-2008, 10:40 PM
Again just tried starting and it barely turned over...
Engine service light is on now and also now says traction failed...
oh well
AND
something new: MAXIMUM RPM 2900
I "TINK" I have a problem said the canary !!!
08-31-2008, 10:54 PM
Go with the the optima batterie. You cant go wrong.
09-01-2008, 11:21 AM
6:15 AM
DEAD-DEAD-DEAD
Guess i walk to StarBucks !!!!!!!!!!!!!!!!!!!!!!
09-02-2008, 01:14 AM
I've been through 2 batteries in 900 miles / 7 weeks. I went out today and bought a Red Top Optima! There's a $25 dollar mail in rebate on them right now at Auto Zone.
2008 H3 Alpha - Boulder Gray
09-02-2008, 05:52 PM
they towed her in this morning...no news yet but they feel its more then a battery...
got a black 08 H-3 loaner...
dam thing has no steps and i'm only 5'6"...!
09-04-2008, 09:09 PM
WELL, ITS BACK...
Just picked her up
AND
after all the speculation...
it was JUST THE BATTERY !
SO
They gave me a FREE NEW Battery (even after 35000 miles)
09-04-2008, 09:40 PM
I think they gave you a new one just to get rid of it. The one they gave me only lasted 2 or 3 weeks.
