Old 11-15-2007, 05:15 PM
BLH2 BLH2 is offline
BLH2 is off the scale
Default REAL WHEELS AIR HORNS
Up for sale is the Real wheels Air horn kit. This kit is awesome and fun. Comes complete with everything needed, Installation is very easy. Was used on wifes H2 for about 1 year. Maybe used 10 times. Only reason for selling is that the H2 was traded in.
Info from Real Wheels website.
With full tank pressure up to 135 psi, this on board air system will not only blow you away with the sound of it's horns, but can also pump up anything else you need. Horn has an exclusive sound chamber, rugged die-cast construction, stainless steel diaphragm, and chrome plating. Doubles as an on board air compressor for external use. Fully assembled for easy installation. Includes everything needed: Dual horns, electric compressor, air tank, hoses, fittings, mounting brackets, extension, and coiled air hose.
All Air Horn components are already attached to the specially designed mounting bracket. Entire unit mounts under the hood with the option of mounting the air horns on the top of the vehicle.
Horn Measurement: 15-1/4"L x 7"W x 3-3/4"H
Decibels: 135db
Model: RW502-1-A0102
Pricing: $549.55 (per unit)
Asking $350.00 with shipping included.
Old 11-15-2007, 08:03 PM
WHOSNEXT's Avatar
WHOSNEXT WHOSNEXT is offline
Default Re: REAL WHEELS AIR HORNS
do you have all parts and instructions?
does it work with regaler horn button?
what condition is it in?
Old 11-15-2007, 09:06 PM
Condition is great, I have all parts. I wired the horn to be used via a switch so that every time I used the horn I had a choice between stock and air horns. I do not have the instructions. You can download the pdf file from RealWheels.com
Old 11-21-2007, 02:50 AM
bump with lowered price $325.00
Old 11-21-2007, 04:34 PM
Shrek_H2 Shrek_H2 is offline
Shrek_H2 is off the scale
I would purchase this off you but the thing is I have a dual alternator setup and it seems the horn will touch the second atlernator....is their other locations its suggested for install?
2003 Hummer H2
2000 BMW DINAN 5 (540i)
2002 HarleyDavidson V-Rod "FOR SALE"
All the great toys are on my driveway.....
Old 11-22-2007, 02:42 AM
Not sure if there is enough room. The horn mounts to the right of the engine block on the fire wall. Where does the 2nd altenator mount?
Old 11-22-2007, 03:54 AM
tower's Avatar
tower tower is offline
Wrong! It mounts on the driver's side of the motor.
Old 11-22-2007, 04:22 AM
to the right of the motor if you are looking at it....
Old 11-22-2007, 06:30 AM
same side next to the other alternator
2003 Hummer H2
Old 11-25-2007, 04:13 PM
BUMP WITH LOWER PRICE. 315.00 SHIPPED
Old 11-28-2007, 11:39 PM
I need to get rid of this my lowest price is 285.00 shipped
Old 12-07-2007, 08:48 PM
SOLD SOLD SOLD
