Old 11-18-2009, 07:09 PM
lonePalm's Avatar
lonePalm lonePalm is offline
lonePalm is on a distinguished road
Default Knock sensor codes
I received a code for the bank 2 knock sensor, I replaced them and the damn thing is doing the same thing again, loss of power and if you hammer it to the floor it either shifts down and you need to feather off the throttle to drop the RPM's to regain power or you hammer it down and the F'n thing goes like a donkey with an upset apple cart. Thank for your help!
Drive fast and Beep the horn!
Old 11-18-2009, 07:59 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Knock sensor codes
Did you check the connector for corrosion. Most cases the connectors get corroded from water getting into the knock sensor holes due to it being trapped under the intake manifold. Was the sensor you pulled out corroded on top, if so you need to repair or replace the connector
1998 Chev Z71
2007 Chev Trailblazer SS
Old 11-19-2009, 06:19 AM
ROUSHDEMON's Avatar
Okay, this has got absolutely nothing to do about this thread... but I just had to say that HUMTECH.... you've got the BEST Avatar in this forum HAHA! I love when you reply to anything bro
2003 Black H2:
2006 Blue H2:
Old 11-19-2009, 08:41 PM
HUMTECH's Avatar
Haha, thanks
1998 Chev Z71
