Old 11-19-2009, 06:39 PM
GRTWHT1's Avatar
GRTWHT1 GRTWHT1 is offline
GRTWHT1 is on a distinguished road
Default Rear diff fluid
What is the reccomended fluid for our rear diff's
I've got some royal purple 75w 140 left over from another project and was hoping to be able to use it here also.
08 SUV birch white LUX
07 SUT birch white LUX
Old 11-19-2009, 06:48 PM
Easy Ed Easy Ed is offline
Default Re: Rear diff fluid
2003 Owners Manual shows for the front and rear diff.
SAE 75W-90 Synthetic
Axle Lubricant
(GM Part No. U.S. 12378261,
in Canada 10953455) or equivalent
meeting GM Specifications 9986115
Old 11-19-2009, 07:01 PM
GRTWHT1's Avatar
Thanks Ed, the 75w 140 was in my f-350
Old 11-19-2009, 08:43 PM
Luv2Camp Luv2Camp is offline
Luv2Camp is on a distinguished road
Just know that, to my knowledge, there is NO 75-90 gear oil out there that meets GM specs listed in the manual. GM also makes their fluid smell like grapes (I am NOT kidding) This is an easy way for them to tell when they drain the fluid if it is genuine GM fluid or not just by the smell test! The stuff is not cheap either..
Old 11-19-2009, 09:17 PM
HumminNBoatin''s Avatar
I replaced my front diff fluid with 75-90. Should not be that hard to find and do. In fact the diffs in the H2 don't even need any special additives as they do not have LSD's.
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 11-19-2009, 10:07 PM
Drained and refilled both diffs 3/27/05 at 29,795 miles with Mobile Synthetic Gear Lube LS 75W-90 and now have 86,624 miles on it and have no probs..... so far. Front diff does have slow leak and when I do the oil changes, I just top it off if required.
Old 11-20-2009, 02:38 AM
When my warranty is up and I change the fluid again, I will go with the Mobil BUT because even Mobil advises that there geral oil does not meet the GM specs, I am not risking a reason for Hummer to deny a warranty claim should I have a differential failure
Old 11-20-2009, 03:23 AM
Understandable....
Old 11-20-2009, 01:38 PM
GRTWHT1's Avatar
What does the manual spec for quantity in the rear diff ?
Old 11-20-2009, 02:46 PM
Service Manual for 2003 shows the rear holding approx. 4.0 Pints/1.9 Liters
Just for the future, front holds approx. 2.6 Pints/0.8 Liters
Old 11-20-2009, 03:55 PM
I just fill it until it starts to come out of the fill hole.
Old 11-20-2009, 05:07 PM
True, but how do you know how much to buy at the parts store if you are changing out the fluid with new
Old 11-20-2009, 05:26 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Just in case....PML shows that their H2 cover's capacity is 1/2-quart over the stock cover.
Old 11-20-2009, 08:28 PM
GRTWHT1's Avatar
Thanks TXSUT I haven't been home long enough to even open the parts bag.
Figured I could poke around here and get some info.
