07-14-2011, 10:48 PM
New GS Creations Tail light tint covers and Ghost emblems!
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
07-14-2011, 11:07 PM
Re: New GS Creations Tail light tint covers and Ghost emblems!
that is hot bro!!! do you have a link to the kit?
07-14-2011, 11:25 PM
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
07-15-2011, 01:14 AM
hows the fitment? Do they stick out away from the light, or are they snugged up on it? How do they attach, 3M?
I just bought the pre cut tint for the tails, but havent tired to put it on yet. This looks way easier.
07-15-2011, 01:22 AM
90$
I think I'll just use my 5$ can of VHT Nightshade
07-15-2011, 01:44 AM
****, Im afraid to use the nightshades on my tails. I used them on my markers and my front turn signals. i went way too dark....both times. I sanded them back down the first time, them sprayed them too dark again. They are staying that way at this point, but IM afraid to have my tails too dark. I will be rear ended before I know it.
07-15-2011, 01:46 AM
i know what you mean... Just got to do very light even strokes with the can. all my lights seem to shine through enough. i only did two coats though and one coat of clearcoat
07-15-2011, 02:12 AM
the first time around i think I did like 5 coats, and 4 coats of clear. i got way carried away with it. Second time around I did 3 coats of paint, 3 coats of clear. The light shines through, but they should be a little bit lighter for sure.
While more expensive, the acrylic covers seem a hell of alot easier.
07-15-2011, 02:25 AM
and thats why they are more expensive
07-15-2011, 03:15 AM
The fitment is pretty snug considering..it's held together by three clear 3M strips so it does not show through..I chose not to do the spray because if I have to remove it I can. I thought about the film but for how easy it was to install these, and how durable they are, it seemed too easy for me. I really like these and they are holding up great so far. Light shows through perfectly as well, consistent all the way through!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
07-15-2011, 03:19 AM
i think they look sexcellent!! thanks for sharing bro!
07-15-2011, 03:23 AM
Anytime! For how easy they are I really suggest it, I've been debating what to do with the tint for so long and I'm happy with my decision. Took me five minutes to put on!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
07-15-2011, 06:13 AM
Id probably get the film also just because when it comes to the taillights i don't really want to mess around with it to much. taillights are serious business
07-15-2011, 06:14 AM
Austin, truck is looking sexxxxyyyyy might i add
07-15-2011, 07:14 AM
Haha. Thanks buddy! I'm dying for a lift! That's all I'm missing!
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
07-15-2011, 08:04 AM
how much of a lift do you want to go?
You're just on the leveling kit right? Either way bro, you're set up is HOT! I think the height looks great with those wheels and the theme you have going on is incredible! This is how i would imagine a white SUT should look
07-15-2011, 10:17 AM
Thanks buddy! And I really want a 4" rancho to stack with my truxxx keys..it'll give me about 7" of lift. Then I'm thinking either 37" or 38" Toyo's
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
07-15-2011, 01:35 PM
Are you sure the Truxx keys will give you 3" more? I thought they were closer to 2"...
07-15-2011, 05:35 PM
They won't give me three, it's just that everyone I've ever talked to about a rancho says that the kit is more like a 6" than a 4". So I'm pretty sure I'll clear 7" with that combo. Bimmer ran the same thing at one point, said he was about 7".
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
07-15-2011, 05:37 PM
I figured that's what you were thinking. Supposedly the Fabtech and Rancho kits are very close in height.
