Old 11-08-2011, 11:12 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
Default Re: questions for my lift....
In theory, yes. But remember, it's the travel you need to worry about, and your mounting points. For example, if you take a Bilstein 7100 series shock with 14" of travel and mount it in a fashion that you have 4" of compression and 10" of extension available, that might not fit what you need it to do.
I don't want to get too complicated here. Really, your best option might be to find others on here with the similar set-up you're after, and ask them to take measurements. Ideally, you'd want three measurements...static, extended, and compressed. But if you get at least the static measurement, you should be able to call a company like Bilstein, and they could help you out.
Sorry if this has made it too complicated.
Old 11-08-2011, 11:16 PM
2010_5thgen's Avatar
2010_5thgen 2010_5thgen is offline
2010_5thgen is on a distinguished road
No i get it. Ill have to start looking at peoples Sig and see if they have done what Im looking for. Thanks for the help.
2012 Porsche Panamera 4
Old 11-08-2011, 11:38 PM
guruerror's Avatar
I can't recall where I got this information, but I'm pretty certain that the Cognito/Bilstein H2 shocks (BE5-A937-H0) are longer than the stock ones; but not long enough to be used with a lift kit. They give you more travel for spaced and leveled trucks.
Perhaps I got the info from someone over at Trail Duty (trailduty.com), I know I was in dialog with them a lot when I was making my shock decisions. Their site does list these shocks as: "Can be used for stock height, torsion key lifted vehicles, or vehicles with Cognito upper control arm leveling kit."
http://www.trailduty.com/product_inf...5fcabbd887a720
Regarding longer shocks in general, one thing that comes to my mind (and I may be WAY off here since I'm not a mechanic), but if your shocks offer too much travel isn't there a chance that a coil spring could come unseated at full extension?
CNTRY
DTOM
Old 11-10-2011, 02:15 PM
charles06's Avatar
Typically, shocks do not be the factor that limits travel. That's what bump stops and limiting straps are for. Remember, bump stops can be used for downward travel, too, not just upward. If you set up your shocks to extend so far that they reach their limit, you run the chance of ruining your shocks.
Old 11-10-2011, 05:35 PM
ive really been thinking about this lately....i think i may just leave the truck as is with the level, then after i get my 37's ill do the lift right and go with something like ranchos 4" lift package. i talked to rancho yesterday and they didnt have a solution for myprble. and i want to do this truck right.
is there other kits that are reasonably priced to give me a 4" lift? or is rancho the best bang for your buck?
Old 11-10-2011, 07:09 PM
skyjacker 5.5" lift kits are 50% off....anyone have any experience with these kits?
Old 11-10-2011, 07:44 PM
ok...ive been looking into this rancho 4" lift kit. does anyone have this kit on their hummer now? they say a 5" backspacing is needed on wheels for this lift. they state the stock wheels wont work. so, i have 20x10 wheels with a 4.5" backspacing...these will work right? are there any cheap 17" wheels that will work with this lift so i could re use my 35x12.50r17's in the winter?
Old 12-15-2011, 03:09 PM
im getting ready to order my stuff for my lift and i have a few questions that Rancho wouldnt help me with.....
Im going with Rancho's 4" lift kit and im going to run 38" toyo's with 20x10 wheels with a 4.5" backspacing.
Now, Rancho said they cant help me with my wheel and tire combo because the testing has been done with the 17x10 with 5" backspacing ,and not what im running. SO.....just to be sure, will my combination work with this lift kit?
Old 12-15-2011, 03:32 PM
guruerror's Avatar
As long as you don't have more backspace than they're recommending you should be fine (less backspace means less wheel under the truck, near the suspension components). So your 4.5" backspace will give you .5" more clearance than the 5" BS rims they tested.
CNTRY
DTOM
Old 12-15-2011, 03:39 PM
Ok. That's good to know. I was getting scared after he said they couldn't help with support.
Old 12-15-2011, 07:21 PM
TTLex TTLex is offline
TTLex is on a distinguished road
The Rancho and 38's will look nice for sure.
04 H2
Fabtech lift- Bilstein shocks- Hotchkins sways- Cognito UCA's- Cognito support kit- Kryptonite tie rods- Spohn adjustable panhard bar- Rancho stabilizer- Suspension Maxx 1.5" spacers- Green keys- Fuel Hostage 20x12- Toyo Open country 40x15.5- Boulder Accessories winch bumper- Warn light bar w/ PIAA 520's- ZMag billet hood vent- Volant intake- exhaust- superchips tuner- linex bumpers/mirrors- E&G fender flares- blacked out lights- kenwood head unit/tv/navigation- headrest monitors
Old 12-15-2011, 08:11 PM
accely's Avatar
accely accely is offline
accely is on a distinguished road
5thgen, I feel like I'm on almost the same page as you on alot of things.
I was considered 40's with 6" lift, but after pricing and some other variables I'm thinking 37/38's with a 4 inch would be better for my taste and price. I'm also looking at the toyo m/t's, what width are you getting to put on your 20x10 rim? I wouldn't mind if I could reuse my rockstar 20x10's.
Also, where do you plan to order your kit from?
Yellow 04' H2
Old 12-15-2011, 08:16 PM
I was going to go with a 13.50 width. Their gonna run me about 1800 shipped. The lift, I'll probably go through summit racing since their kinda in my backyard.
i may wait until after christmas to see if anyone has any end of year deals. hopefully theres some.
Old 12-27-2011, 01:39 PM
well, i got everything ordered for my lift.rancho kit. 5 toyo 38's.extra 20" spare. shocks.....just gotta get black lug nuts. any recommendations?
Old 12-27-2011, 04:26 PM
charles06's Avatar
This probably isn't your best option, but you could always rattle-can a set of stock ones. At least that would buy you some time to look for black ones.
charles06's Avatar
charles06's Avatar
Old 12-27-2011, 04:36 PM
4 of the wheels are at the powdercoaters. The other wheel will be there when the 4 get done. Hopefully everything will be on the truck middle of January.
Does Anyone know How long it takes to install the rancho kit?
Old 12-27-2011, 04:55 PM
guruerror's Avatar
I ordered 35 of these when I got my Rockstars from http://discount4wheel.com. I'm pretty certain they were Pro Comp, but I don't have any record of the part number.
CNTRY
DTOM
Old 12-27-2011, 05:05 PM
their web sites not working for me right now. how much are they for a set?
