Old 11-21-2006, 09:57 PM
ree's Avatar
ree ree is offline
Default Part #s? - Front and rear window sealing strips...
for an '03 H2. Thanks in advance.
'03 pewter base H2
Old 11-21-2006, 10:17 PM
partsguy partsguy is offline
Default Re: Part #s? - Front and rear window sealing strips...
At the bottom of the glass where you would rest your arm?
Old 11-21-2006, 10:26 PM
ree's Avatar
ree ree is offline
At the bottom, but on the outside. If you have SI manuals handy, these are the strips referred to in:
Document ID# 841744 - Sealing Strip Replacement - Front Door Window Belt Outer - Front
Document ID# 841785 - Sealing Strip Replacement - Rear Door Window Belt Outer
I want to replace them to try to remedy a wet streaking problem.
'03 pewter base H2
Old 11-21-2006, 10:44 PM
D/S Frt-15101755
P/S Frt-15101756
D/S RR-15101757
P/S RR-15101758
Number's may change my DMS is down at the moment.
Old 11-22-2006, 12:14 AM
ree's Avatar
ree ree is offline
Thanks.
'03 pewter base H2
Old 11-22-2006, 06:00 PM
ree's Avatar
ree ree is offline
Holy crap. At gmpartsdirect.com:
D/S Frt-15101755 = $50.14
P/S Frt-15101756 = $34.76
D/S RR-15101757 = $49.92
P/S RR-15101758 = $47.54
Maybe I can live with streaks on my windows.
'03 pewter base H2
