Old 01-03-2005, 02:49 PM
JamesT's Avatar
JamesT JamesT is offline
Anyone have problems with the horn fuse blowing often?
People Who Annoy Me...NAGGERS
JamesT's Avatar
JamesT's Avatar
Old 01-04-2005, 12:17 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
Sounds like you need to lay off of the horn!
Maybe a bad ground, or you could've gotten some mud jammed up between the pos. and neg. contacts!(oops, sorry, I thought I was talking to an offroader!!! )
Ric-H2
www.meatspin.com
Old 01-04-2005, 12:47 AM
ChuckE ChuckE is offline
ChuckE is off the scale
There are two vibrator-type horns on the H2, and vibrator horns can possibly - if not adjusted correctly draw a lot more current than they should. What you might do is disconnect one (it should be a simple plug on the horn itself) and lay on that single horn (sure hope you have understanding neighbors ), to see if the fuse blows. If not, then replug it and then unplug the other. Do the same test again.
With the one that blows the fuse, you might be able to adjust it so that it draws less current. See if there is a screwdriver adjusting point on the side. If not, then you could just replace it (two horns, one is the "hi note" the other being the "low note").
If you can prove the horn blows the fuse, you should be able to get it replaced under warranty; if not then, good replacement OEM-like (or even louder) horns should about $15.
\"I asked my wife for a hummer, she gave me this H2.\"
03 White H2 Adventure, sunroof, Garmin GPS, Air Horns, Diablo Sport Programmer
Old 01-04-2005, 11:55 AM
JamesT's Avatar
Look, for the last time "Hunter Boy". I AM an Off ROADER. Last week I conquered 2 curbs as well as a parking block at the mall. NOW LAY OFF!
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by RIC-H2:
Ric-H2 <HR></BLOCKQUOTE>
Old 01-18-2005, 01:56 PM
JamesT's Avatar
Just as a follow up. I replaced the 15 amp with a 30 amp and it works fine. ????
Old 01-18-2005, 04:20 PM
Did you look for an adjusting screw on the side of the horn?
Like I said earlier, if adjusted wrong (there is a range) the average amount of current draw will be higher than at other points, and the general loudness is adjusted by that screw as well.
