Old 08-14-2007, 05:57 PM
tomp's Avatar
tomp tomp is offline
Default need stock ride height
please let me know stock front ride height from center of front wheel to bottom lip of fender flare
Old 08-14-2007, 09:47 PM
tomp's Avatar
Default Re: need stock ride height
Anyone?
Old 08-14-2007, 10:34 PM
Vettster Vettster is offline
25 1/2" on my 06 SUT.
Old 08-15-2007, 12:31 AM
tomp's Avatar
Thanks Vett!
Old 09-14-2007, 11:50 PM
H2 007's Avatar
H2 007 H2 007 is offline
H2 007 is off the scale
Has anyone ever measured what would be close to level on the front?
From the ground up to the bottom of the fender flare on mine (stock) is 42 1/2".
I think on my last one (a 2005) it was 43", which made it a little more level. I recall having an alignment done after wards, but figured I see if anyone else has raised the front some to level it out a bit.
I do recall the ride was a little firmer, which I actually preferred as with stock it seems like it wants to 'lean' some while going around corners.
Thanks!
2008 H2 Graystone Metallic
Old 09-15-2007, 12:56 AM
IRA51's Avatar
IRA51 IRA51 is offline
you would be better off measureing from the frame to the ground on a level cement slab. body or fender lip is very hit and miss,too many variations.
A government big enough to
you have.
-- Thomas Jefferson
