Old 09-17-2010, 02:41 AM
Red face Parking Brake Help
My parking brake wont go down at all.
it's in the full up right position and i can not get it to go down at all not even 1 click nothing.
what can be wrong?
it was working fine and now nothing
any ideas or items that i should check out before i take it to the dealer?
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 09-17-2010, 05:35 AM
twr's Avatar
twr twr is offline
Default Re: Parking Brake Help
hi the front parking brake cable is likely seized.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
Old 09-17-2010, 09:43 PM
Wink Re: Parking Brake Help
it was working fine and then the next time it's stuck.
so change out the cable?
easy fix or dealer fix?
anyone have a write up?
Fabtech Tie Rods
Old 09-17-2010, 10:10 PM
twr's Avatar
twr twr is offline
Hi to see if its a cable seized you can unhook it at the pedal ass. and if the pedal moves down, its one of the parking brake cables siezed. It could also be in behind the rotors where the parking brake shoes are, but likely its one of the cables. There is 3 cables front, L rear and R rear. I am not sure how mechanical you are but if its a rear you need to remove tire, brake caliper and rotor to get at where the cable is hooked to the parking brake shoes. Hope this helps.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 10-18-2010, 05:27 PM
Red face Re: Parking Brake Help
FYI
fixed my issue, turns out the parking brake lever assembly sezied up and i had to replace the complete assembly.
even after the old one was removed, the old foot brake lever wont go down.
Fabtech Tie Rods
Old 10-18-2010, 11:57 PM
twr's Avatar
twr twr is offline
Originally Posted by Cesardajr
FYI
Hi glad you got it fixed. The parking brake lever assembly doesn't usally seize, its usally a cable. You should try to use the parking brake once a week to keep everything from seizing.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 10-19-2010, 12:06 AM
Olfart's Avatar
Olfart Olfart is offline
Olfart is on a distinguished road
a little spray type lube about every 6 months on all pivot points including the p brake lever can't hurt either
2004 Black H2
Old 10-19-2010, 12:14 AM
twr's Avatar
twr twr is offline
Hi your correct
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
Old 10-19-2010, 03:59 AM
i use it everyday.
i will lube it as mention, the dealer said it was the first ever they came accross with this issue.
Fabtech Tie Rods
