Old 07-03-2005, 07:32 PM
J J is offline
J is off the scale
i just would like to know if anyone has experienced this system and if so did it cause your vehicle lots of backpressure? how was it driving on the highway and streets? was there any power? or is there any lagging?
http://www.magnaflow.com/02product/s...=Trucks&id=109
J J is offline
J is off the scale
http://www.magnaflow.com/02product/shopexd.asp?zone=Trucks&id=109
Old 07-03-2005, 09:14 PM
Mr. H Mr. H is offline
Mr. H is an unknown quantity at this point
I installed the Magna Flow muffler and left all my other exhaust system stock. It increased my MPG about .5 to 1 mpg. Sound is good as well.
White 05 Lux, 35\'s on 18 MKW M19s, Manic guards and roof racks, Magnaflow muffler and NAV.
Old 07-04-2005, 01:01 AM
MotorsportsAuthority aka Dragon's Avatar
MotorsportsAuthority aka Dragon MotorsportsAuthority aka Dragon is offline
MotorsportsAuthority aka Dragon is an unknown quantity at this point
magnaflow is an excellent system. go ahead and get it.
01 Toyota Celica GT-T .:|:. 04 Chevrolet 2500HD Duramax .:|:. 01 Lexus RX300 .:|:. Under Construction
Owner: Motorsports Authority, Inc.
MYSPACE
Old 07-04-2005, 03:57 AM
sclui56 sclui56 is offline
sclui56 is off the scale
Had mine doneat Royal Miffler in Chatsworth, call up & ask for Jimmy, great guy & clean install.
(818) 993-9004
http://elcova.com/groupee/forums/a/tpc/f/6706011751/m/126109...261092701#1261092701
Old 07-04-2005, 09:56 PM
4churchill is off the scale
Flowmasters here, love the sound, and quality
www.HUMMERNut.net
Old 07-04-2005, 10:18 PM
SoonerBoarder's Avatar
SoonerBoarder SoonerBoarder is offline
SoonerBoarder is off the scale
I have the Magnaflow Cat back and I installed it myself. I really like the sound, although you may consider it loud at higher RPM under load.
As far as the fit, etc, it's the best I've ever seen. My last vehicle had a Gibson and this one blows it away. It took me about 30 minutes to install and that counts unboxing, getting out and putting back the tools, and everything. The hardware looks exactly like factory and it fits perfectly. You should be very happy with it.
Old 07-04-2005, 10:20 PM
Oh, there wasn't a lot of power difference either way, btw. It drives fine. When I'm pulling a trailer and going around 70, it's at a loud spot in the power range and that gets a bit annoying, but other than that, no problem. I'm sure the stock muffler would be just the same under the same circumstances.
Old 07-05-2005, 05:44 AM
HummBob's Avatar
HummBob HummBob is offline
I love my Magnaflow Catback Exhaust.
Increased mileage by 1 MPG, but that's not the reason I wanted it. It was for the sound! The deep throaty rumble is a perfect match for the H2.
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 07-06-2005, 01:04 AM
ARH1956 ARH1956 is offline
ARH1956 is off the scale
I have the Magnaflow Cat-Back as well. One thing you need to know, with the gearing of the H2 you'll be turning over 2K+ rpm at 70-75 & it's somewhat noisey while Interstate cruising, & loud when it downshifts on a grade. If you've got a nice sound system, or rear seat video system you might be put off by this with the Magnaflow. You'll truly love it around town however.
Old 09-19-2005, 11:44 PM
VTSTOMPER is off the scale
Are their U bolts or clamps to put this on? Do you have to cut your stock exhaust?
I bet the sound will not be bad in the cab of the SUT...
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-20-2005, 12:09 AM
It bolts up almost exactly like the factory system & uses the stock hanger locations. But to more clearly answer your question it uses U-Bolt style clamps & bolts to the factory flange in front.
Old 09-20-2005, 10:11 AM
Thanks ARH1956!
I am thinking about picking one of these up. I have seen them around for about 499.00 shipped to me...is that about what I should plan on paying?
Old 01-14-2006, 08:18 PM
any pics?
Old 01-14-2006, 08:54 PM
alright, I found one pic - and not loving how you can see the tips.
Old 01-16-2006, 02:22 PM
Rotary Flyer Rotary Flyer is offline
Rotary Flyer is off the scale
I've used them on several trucks and I think they're one of the best. I seem to get a little more power and a bit less noise with them. Over all I rate them the best I've used!
Mike S
Mike S
03 Pewter H2
