Old 02-16-2011, 12:45 AM
Humdingah Humdingah is offline
Humdingah is an unknown quantity at this point
Default Backup Cameras
Does anyone have any experience with either of the following two backup cameras and, if so, can you give me any pros/cons (ease of install, quality of picture, field of view, etc.) that you found?
http://www.carelectronicsworld.com/hummerh2colormatchedbackupcamera3rdlightmount.aspx
http://www.mobilevideo4less.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=MV&Product_Code =RVH2PKG&Category_Code=BKSYS
Thanks in advacen for any advice you might have...
Dan
Old 02-18-2011, 06:59 PM
[__--MUD--__]'s Avatar
Default Re: Backup Cameras
I have about 6 of the color matched cams somewhere in my basement. I'll see if I can put my hands on them.
Old 02-18-2011, 07:07 PM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
I'd be interested if you find the box
Old 02-18-2011, 09:06 PM
Let me know if you find them also...migh tbe interested in grabbing one from you.
Dan
Dan
Old 02-19-2011, 08:53 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
I'm real interested as well. I have the HCam now and the lens is starting to get foggy. Do you happen to have Pewter?
Old 02-19-2011, 04:34 PM
if your lens is foggy, i'd try some C-L-R or ammonia on a q-tip.... Its probably just hard water stains on the glass lens.
If you just want to swap out the camera, you can find similar ones from $50-$100. Its just glued into the fiberglass shell. Jump on one of the big security camera/cctv sites, somewhere around mini, micro or pinhole category should be alternative replacements. There was a part number on one of the camera bodies, but i dont remember if I ever found the exact match.
I literally have about 12- 40gallon totes of xmas lights I need to take down first, and another 15 totes worth of lights I have to sort, test, and box up for next year before I can start digging for the cams. Don't expect me to find them this weekend.
