Old 08-13-2006, 09:16 AM
rjmoose rjmoose is offline
rjmoose is off the scale
Default Shorter Antenna
My Antenna on my brand new H3 hits my garage door badly every time I go in and out of it. Can you guys give me any advice/recommendations on either of the following products:
http://www.antennax.com/images/antennax.jpg
OR
http://www.gstyle4u.com/.sc/ms/dd/ee/787/HUMMER%20H3%20SHORTY%20ANTENNA%20%5E2F%202006%20HU MMER%20H3
Thanks in advance.......
Old 08-13-2006, 11:18 AM
DarthKarl's Avatar
DarthKarl is off the scale
Default Re: Shorter Antenna
I have an antennax installed. I didn't like the big whip antenna when I first got my H3.
The shorter antenna works fine. However there will be a reduction of some radio reception, but since I mainly listen to XM it really doesn't matter much to me.
Old 08-13-2006, 03:32 PM
humdoug's Avatar
humdoug humdoug is offline
humdoug is an unknown quantity at this point
I have this exact antenna and it works great.
Old 08-14-2006, 03:53 AM
J6Niner's Avatar
J6Niner J6Niner is offline
J6Niner is off the scale
I have the same problem...l have removed the antenna several times since I don't use AM/ FM much. But it also helps to gauge the height of parking garages /etc. I am on the fence about the short antenna.
2006 Boulder Gray H3 / Adventure / Auto / XM / Side Steps
Previous:
2004 Nissan 350z
2002 Jeep Wrangler Sport
1997 Honda Accord EX
1994 Jeep Wrangler Sport
1980 MGB
Old 08-14-2006, 03:56 AM
I went with this one:
http://snipurl.com/uwc1
Thanks for all the responses....I really appreciate you wealth of knowledge here on the hummer forum....
Old 08-14-2006, 06:45 AM
H3slate's Avatar
H3slate H3slate is offline
The long antenna is a great gage for parking garages. It does unnerve you a little bit when you start hitting the ceiling with it, but is better than scraping the roof.
Old 08-14-2006, 05:24 PM
auto zone or pep boys, look for the universal small whip. 12 bucks and your done
Old 08-14-2006, 07:53 PM
phantom2's Avatar
phantom2 phantom2 is offline
phantom2 has a little shameless behaviour in the past
I've tried two of the antenna listed above and I really don't want to knock any brand names or vendors, but they are crappy.The rubber one gets permanently bent like a pretzel as soon as you do 50mph.My best advice is "you get what you pay for".I personally would spend a few extra bucks and purchase a quality item.
War is not hell...it's worse
Old 08-14-2006, 07:57 PM
I'm poor white trash, works for me, looks like I'm traveling fast all the time
Old 08-14-2006, 08:02 PM
I agree, so which "quality" one would you suggest?
Old 08-14-2006, 08:28 PM
blindzebra's Avatar
I have xm so I dion't listen to he radio that much, but does the shorter antenna get as good of reception as the long one?
Old 08-14-2006, 08:39 PM
phantom2's Avatar
White Trash...no way,they'd use a coat hanger
Old 08-14-2006, 08:47 PM
DWPC DWPC is offline
DWPC is an unknown quantity at this point
Mine hits the bottom of the garage door when I pull in or out. There's nothing for it to snag on, so aside from the clatter, I figure it won't do any harm. I'm in a fringe area and don't want a stub antenna. I worry more about my roof rails, which sometimes catch a little door edge too.
'06 H3 Adventure (9/2005-1/2013)
Old 08-15-2006, 10:29 PM
Wisha Haddan H3's Avatar
Originally Posted by blindzebra
... does the shorter antenna get as good of reception as the long one?
I'd like to know this too.
Old 08-15-2006, 10:46 PM
DarthKarl's Avatar
No.
In urban areas, like Denver you really can't hear much of a difference since there are a lot of high powered radio transmitters close around. But out in the sticks (where you're listening to stations further away) the short antenna doesn't do as good. I'd guess at about a 20% - 25% reduction in long range reception.
Old 08-15-2006, 10:47 PM
NM H3's Avatar
NM H3 NM H3 is offline
NM H3 is off the scale
I have had the antennax one for 9 months now. I never noticed a change in reception quality. I have been pleased with the functionality and the look. No complaints. I have had no problems with reception.
Old 08-15-2006, 10:49 PM
NM H3's Avatar
It has not bent either, still straight.
Old 08-16-2006, 05:06 PM
jp's-h3 jp's-h3 is offline
I purchased my stubbie antenna from antenna-x on ebay(about $13.00).
the reception seems to be every bit as good as the factory antenna.
And it's very cool!
Old 08-16-2006, 05:14 PM
fourfourto's Avatar
And it's very cool!
I like the red top it matches
I dont mind the long antenna it warns you of low branches
Old 08-16-2006, 05:26 PM
I was told that if i lose some weight my antenna would not seem so small
