Old 09-12-2005, 08:09 PM
Brian H's Avatar
Brian H Brian H is offline
Brian H is off the scale
I'm still waiting on my H3 order. Just wanted to check here to see if any one knows if Gasohol will work in the H3 or if it will harm it?
Thanks in advance for any info.
Brian
HUMVH3
Brian H's Avatar
Brian
HUMVH3
Old 09-22-2005, 12:51 AM
Lucci Lucci is offline
Lucci is off the scale
Are you refering to E-85? If so we are the unfortunate ones. Many of GM's vehicles (mostly trucks) will run on E-85. You can look on the window sticker, or often times it will say inside the gas cap, though I guess there isn't such a location on our vehicles
Some places this stuff is 50-70 cents a gallon cheaper than regular unleaded, which around here often times has 10% corn gas!
E-85 is also over 100 octane though it will give you about 10% less fuel efficiency.
Old 09-22-2005, 03:14 AM
Brian H's Avatar
Thanks for the reply Lucci,
I am have no ideaif it is also called E-85 although I do know it is made from corn. We have a local farm market that sells farm stuff, gasoline, and gasohol. I used to use it all the time in a Chevy Silverado that I had. It worked excellent. I'll do some more research on it and also ask the dealer about it.
Thanks,
Brian
HUMVH3
Old 09-26-2005, 03:23 PM
H3 is not e-85 approved. e-85 is 85% ethanol, 15% gasoline, and not that many vehicles can burn e-85. h3 is compatible with gasohol; 10% ethanol, 90% gasoline
Old 09-29-2005, 01:38 AM
H3 is not e-85 approved. </div></BLOCKQUOTE>
Isn't that pretty much what I said?
Anyhow
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">not that many vehicles can burn e-85 </div></BLOCKQUOTE> All things are relative; if you mean not that many models you are correct, but there are a lot (millions) of vehicles out there that can run on E-85. Many of the vehicles that can run on it are high volume vehicles.
Old 09-29-2005, 09:15 PM
MyxH3 MyxH3 is offline
MyxH3 is off the scale
May the next exit offroad be anywhere you want it to be.
