Old 06-11-2004, 02:36 PM
William maxey William maxey is offline
William maxey is off the scale
i want to run the new toyo 40x15.5 r 22 on my h2 but am not sure how little lift i can get away with..? will the rancho work..? fabtech.? i really do not know and als does anyone have any pics of a h2 on 40's? that is still practical..?(i mean not sitting 12" of lift)
Old 06-11-2004, 03:03 PM
fallen fallen is offline
fallen is off the scale
I have the Rancho lift and i have 39.5" tires, doesnt rub under normal driving conditions only when i am offroading and i take a bump too fast while turning here is a picture
Old 06-11-2004, 03:15 PM
that look nice that is the look i want no i just need a 22x12" rim and there is not one avalable so i might mill down a set of 22.5" floater rims(alcoa's)
is that a 20 or an 18 inch rim..?
Old 06-11-2004, 03:22 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
I have Skyjacker 5.5" with 38 x 15.5
Minor rub under fenderwells when offroading. would recommend 6" lift minimal for anything bigger.
Jerry
Old 06-11-2004, 03:34 PM
The wheels on my H2 are 20" Wheels
Old 06-11-2004, 03:40 PM
Detonate Detonate is offline
Detonate is off the scale
There was someone here running 40" MT/R's, but I can't seem to find the post about them.
</center><hr>
Old 06-11-2004, 04:35 PM
Dan Dan is offline
Det, you talking about this guy?
http://www.elcova.com/h2/frankh2.jpg
Those are GY 40's. I can't seem to find his post about doing the lift though.
There's this guy too:
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=2606011751&m=708600875 2&r=7086008752#7086008752
Old 06-11-2004, 04:47 PM
Dan Dan is offline
Found the first guy's website:
http://www.myhummer.net
Old 06-11-2004, 05:17 PM
Yeah, that is the dude I was thinking of.
</center><hr>
Old 06-11-2004, 06:44 PM
Hummer H2 Hummer H2 is offline
Hummer H2 is an unknown quantity at this point
I know that with the fabtech 6" kit you can run the goodyear 40x13.5 tires without rubbing. I don't think that you can go any wider though.
Old 06-12-2004, 03:01 AM
So Cal H2 So Cal H2 is offline
So Cal H2 is off the scale
I am Running 38x15.5x20 Toyos on my H2 with 6" lift I would say 6" min for 40" wheels.
2003 Blk H2 Lux,CST 6\" Lift,Fox Shocks
20X10 Kaotik Wheels 38X15.5X20 Toyo M/T
Magnacharger,Volant Intake,Volant S/S Exhaust.
Old 06-18-2004, 03:28 PM
do i need a blower/supercharger to get this thing going on 40's or will intake chip and exhaust getr me by..?
Old 06-18-2004, 03:33 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by William maxey:
do i need a blower/supercharger to get this thing going on 40's or will intake chip and exhaust getr me by..? <HR></BLOCKQUOTE>
What you will really need is some gears for the truck. I've been waiting for the front 4.88's to be released that will help you out a lot. I have intake exhaust (complete exhaust headers high flow cats true dual) chipped and its still damn sluggish. I average about 7.5 MPG around town with that setup.
Old 07-24-2004, 01:45 AM
HGW HGW is offline
HGW is off the scale
fallen---where did you hear that they are going to make 4.88 gears for the front diff? I'd like to look into it. All my sources (plus GM) says the front diff will only support 4.56. I'd love to have 4.88s vice 4.56--please let me know where you heard this---thanks.
Definately use 6" plus lift for 40's x 15.5's to not rub--I have a true 6.5" FTS lift with tweaked torsion bars for close to 8"---I have 38 x 15.5's, and good shocks--could go to 40" easily.
I am skeptical on the 5.5 and 6 kits because they spread the upper amd lower control arms with different spindles--them you put 40" X 15.5" on with heavy 22' wheels ---it is OK but watch heavy abuse type on or off roading.
The FTS kits (and others) lower both the upper control arms and the lower control arms maintaining factory spindles, rather than just speading the upper and lower by dropping the lower like fabeck and skyjackerusing new spindles---I know no one who has been happy with the skyjacker kit.
Old 07-24-2004, 06:05 PM
HGW HGW is offline
No, you do not need a supercharger BUT you will need a new set of front and rear gears unless you want the stock sluggish beast to be even more sluggish, especially in mid reange like when trying to pass someone on the highway.
4.56's front and rear will do the trick--the H2 will perform about the same as with 35's and the stock 4.10 gears. (the weight of the new tires and wheel will slow it down a fraction) Anything you add for performance will make it run even better.
