Old 12-10-2007, 11:20 PM
Viet Nam Vette's Avatar
Default WTF Is That Noise...The Motor's Off And I'm Not Moving?? My 3 is Haunted...
This is the secod time I've heard this on my 2007 H3. Once before while I had the hood up installing a new Horn set up ..and 2 days ago while the hood was up installing a connection to the battery for an external charger.
The motor is off and the key is not in the ignition.
It's this clicking sound that appears to be coming from near the Master Cyl on the firewall. It doesn't start right away but a few min later. I hear this click about every 2-3 seconds. Of course after I shut the hood I can't hear it any longer.
WTF is that all about..???
Old 12-11-2007, 12:34 AM
Default Re: WTF Is That Noise...The Motor's Off And I'm Not Moving?? My 3 is Haunted...
Someone had something similar on an 06. I remember reading about their problem here, but I forgot what they found.
Old 12-11-2007, 04:11 PM
joelasky joelasky is offline
joelasky is off the scale
I think it the heat shield, mine does it also
Old 12-11-2007, 05:31 PM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
My '06 doesn't do it, but the '08 loaner I'm using does. It stops after about maybe 15 minutes. I think it's the heat shield, too. Had you been driving just prior to hearing the clicking sound? The loaner does it after I had been driving for even a short distance ..and then I park, turn off the engine .. and the clicking begins.
Old 12-11-2007, 05:58 PM
This isn't that clicky sound that you hear when the exhaust manifold shields are cooling down. This is a realy sound. It is definitly a relay being turned on and of every 1-2 seconds.
Old 12-11-2007, 11:44 PM
Desert Dan's Avatar
It may have something to do with the power brake system on the master cylinder?
It uses an electrical boost system. I haven't really looked into how it works.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 12-12-2007, 04:28 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Best guess, just what desert dan said, the abs system runs self diagnostics which are quite audible(apparently) have not heard it myself. Also not sure if they will run in a key off situation. If i come across anything tomorrow i will pass it on to ya. I checked for service bulletins and pi's and found nothing. May want to check for any chassis dtc's.
Old 12-12-2007, 05:09 PM
Thanks Dude...
It may well be some sort of diagnostics thingy. There is a module next to the MC where the sound is coming from. But it takes a while after the hood is up before ut starts clicking.
Pop your hood and wait a few min..it should start. Their are no codes shown either on the dash or on my after market "Scan Gauge" mounted on my steering column.
No big deal..just wondered WTF it's doing.... "I Robot"
Old 12-13-2007, 03:57 AM
HUMTECH's Avatar
Well i dont have one but next time i do have one in the shop i will def check it out and see if it happens. May be normal or may be posessed
