09-15-2007, 06:47 PM
Service Air Suspension?
ok, i just changed out both of the rear suspension air bags and now it's reading "service air suspension" it was working fine after the bags were installed but now i don't hear the air compressor turning on. does anyone have a clue what the problem could be?
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
09-15-2007, 07:01 PM
Re: Service Air Suspension?
Try disconnecting the neg battery term. for 10 mins to reset the computer.
09-15-2007, 07:19 PM
Make certain that the valve cap is on your compressor nipple.
09-15-2007, 07:27 PM
where would that be located? i only replaced the air bags...i didn't touch anything else.
2018 Polaris GEM e4
09-15-2007, 07:52 PM
It's the fitting by your air compressor switch to whitch you attach the tire filler hose. It looks like the top end of a schraeder (tire) valve. Leaving it uncapped will produce the exact problem you describe.
09-15-2007, 08:12 PM
i've never had a cap on that valve but i will be sure to put one on it from now on.
2018 Polaris GEM e4
09-17-2007, 02:26 AM
 I have never had a problem without a cap on my hose fitting. I think I lost it about a month after I got the car. 2 years and no problems. If you're losing air thru that fitting, I'd say theres something wrong with it or the compressor wouldn't ever turn off.
CBR : I replaced an airbag on my rig once, (2 days old) and we didn't have to recalibrate the computer.
09-15-2007, 08:14 PM
ok, that worked...i disconnected the battery for about 15 minutes and everything seems to be back to normal
2018 Polaris GEM e4
09-15-2007, 11:45 PM
Anytime any air suspension components are changed A ride height calibration needs to be done which to my knowledge only the dealer has the right tools to do. Need A tech 2 scan tool and ride height calibration blocks. The light may be out but that doesn't mean ride height is learned.
09-16-2007, 03:31 AM
ok, i'll keep that in mind. however, everything seems to be fine for right now after i disconnected the battery for a while. i'll keep an eye on it to see if anything changes. i would hate to have to go to the stealership just to get the system calibrated...i'm sure they would charge me at least $120 flat rate.
2018 Polaris GEM e4
Hybrid Mode
