Old 12-25-2007, 11:15 PM
porschett's Avatar
Default Disc Brake Milage
I was wondering what kind of milage any of you are experiencing before you have to change the pads. I'm starting to get a squel out of mine like it's the wear indicators.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 12-25-2007, 11:25 PM
tower's Avatar
tower tower is offline
Default Re: Disc Brake Milage
~50K miles of hard on & off road. Still good on originals!
Old 12-25-2007, 11:31 PM
porschett's Avatar
Thanks, thought it was a little early with only 15K. Must be dust buildup, I'll take her out and hit em!
2008 GT2 Porsche
2009 DBS
Old 12-26-2007, 04:14 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Huh, that doesn't sound right.........almost 70,000 miles and still no (knock on wood) problems....
Old 12-26-2007, 03:49 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
I have noticed some squeal over the hot summer months after the wheels start to show brake dust. Im guessing that due to the size/weight of the H2 that the pad compound is a bit on the aggressive side... these types of pads will produce a squeal after some dust build up. My stock brakes on my Z06 would start to squeal after about 50 or so miles of hard driving. Probably wouldnt hurt to pull the wheels for inspection (I have seen calipers hang up and prematurely kill a brake pad) but I am willing to bet its nothing to worry about.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 12-27-2007, 12:31 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I have seen them last for over 200,000 km. they should be taken apart and cleaned from time to time. Lube the slide pins with silglyde(silicone based lube) as well you can lube the backing plates of the pads which will help eliminate squeal caused by the steel pads vibrating against the caliper. Also clean and lube the steel sliders.
