Old 04-17-2008, 03:07 AM
brad barkis's Avatar
brad barkis brad barkis is offline
brad barkis is on a distinguished road
Default Lift kit
I want to lift my h1 a couple of inches. I see a spring block, and balljoint kit that rubberduck has for over 2k dollars. Does any one have any suggestions? Thanks!
Old 04-17-2008, 03:21 AM
phazer42 phazer42 is offline
phazer42 is on a distinguished road
Default Re: Lift kit
suspension or body?
as you metioned, Duck has a suspension kit, he also has a body kit...
I believe the kit that Charles Piper makes, runs around $800 and that is the spring block for a suspension lift but I believe it also includes a set of springs....
if you wanna read up on them, or get some entertainment goto the forum on humvee.net, lots of discussion on them there....
Old 04-17-2008, 05:39 AM
NoMoGMPG's Avatar
NoMoGMPG NoMoGMPG is offline
Since when is Charles offering his lift design for sale? I know he and Breggin discussed it, but I thought it was a dead deal.
I have the prototype of Rubberducks "Big Duck" lift on my truck, and was in on the torture testing before it was brought to market. It's a good, easy to install design, doesn't entail massive reworking or welding of any kind (JabbaFabba design), and maintains usable drivetrain angles. I have never broken anything related to the lift.
In short, "Works as advertised".
Old 04-17-2008, 05:58 AM
ssgharkness020147's Avatar
It has been out for well over a year. I've got one on my truck.
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 04-17-2008, 07:47 PM
Well this is good news. I was thinking of ordering RubberDuck's 3" suspension lift. Any feedback on lifting the Alpha?
HI NOMO!! I got the mac daddy H1 now baby!
Old 04-18-2008, 05:10 AM
NoMoGMPG's Avatar
Hey Rox! I see you're one of the few Alpha owners actually taking advantage of its capabilities. Great job!
If you want my opinion, since you DO actually go wheeling on more than dirt trails, you would benefit from the suspension lift only if you wanted to go to 39.5 or larger tires. Otherwise it would look goofy with the 37's.
The 40 MT/R would be perfect for you, since you drive yours both on and off highway. Best part is you don't need to do a body lift since the Alpha is already lifted (and with the 12" brakes I might add).
Oh and yeah, I'm jealous.
Old 04-18-2008, 05:51 AM
Rox, Do you still have the 37's on there? If so why not try getting some 39.5's-40's under there and see how you like that first? Like I said in the other thread I'd hate to see you have warranty issues over the lift. If you do go that route make sure to talk to your dealers service dept. first to make sure they aren't gonna hassle you about it.
-007=
Old 04-18-2008, 05:18 AM
NoMoGMPG's Avatar
Is that through Dave Breggin?
How does it address the upper ball joint angle issue? Charles told me he put his upper control arms in a press to bend them at the proper angle, at least when he first did the lift. I hope it (the lift kit) is more than just the spring tower spacers. I'm curious about the materials used in that kit, since I know the Rubberduck kit spacers and the balljoint angle wedges are made from a very high tensile material to prevent mushrooming.
Old 04-18-2008, 05:49 AM
Yes. The kit is through Dave B. I think the spacers are made from steel, and the springs are from Hypercoil. There are no ball joint spacers, I believe Travis' product has that patented. From what I remember Charlie saying he did not feel that the ball joint shims were paramount. Personally, I'd rather have the shims than not, but with Charlie having taken his truck to hell and back I'll trust his judgement. All and all my truck aligned to a fraction of the stock angles, so far the tires have not shown any odd wear.
-007=
Old 04-27-2008, 03:19 AM
remember, manufactures have different ways to measure the tires... so a 39" tire from BF Goodrich isn't the same as a 39" tire from Good Year etc.....
