Old 04-30-2012, 10:24 PM
ryaleon's Avatar
ryaleon ryaleon is offline
ryaleon is on a distinguished road
Default Only Highs...no lows.
So the bulbs arent burned out. And the fuses I checked associated with the low beams are fine as well. Hi beams work fine. just no lows. Is it the switch? Will a simple swap fix this issue?
Old 04-30-2012, 11:13 PM
NEGATE's Avatar
NEGATE NEGATE is offline
NEGATE is off the scale
Default Re: Only Highs...no lows.
could it be a relay?
Old 05-01-2012, 12:06 AM
ryaleon's Avatar
Relay is good, switched it with another and they are both good
Old 05-01-2012, 01:15 AM
[__--MUD--__]'s Avatar
If you only checked one, then you didn't get it. There are two.
Old 05-01-2012, 01:17 AM
There are also 2- 10Amp fuses coming off each relay for left/right light.
Old 05-01-2012, 01:25 AM
Screw it, here's the diagram. If you have any more questions, ask
Old 05-05-2012, 04:13 PM
I thought this was going to be about BOSE.
