  #81
Old 03-25-2005, 10:15 PM
dochummer's Avatar
Hey, I work with body parts, not electrical stuff (my brother-in-law laughs at me everytime we're building/working on something...can't even get the tool names right...). Yes, it's a diode. It's from radioshack...I know the part number is listed somewhere here on the site, might actually be in this thread... If you can't find it, let me know...actually, let the members know, they'll direct you.... It only cost about $1.
And, yes, you're right. During the day, the DRL's are on only. At night, when the headlights turn on, the drl's stay on. They pretty much run night/day... I don't have the option of turning on the DRL's on without the headlights though, which is what the other connection will accomplish.
'03 H2
Old 08-14-2005, 05:36 PM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
almost 2 years later...I finally did it.
Old 08-14-2005, 06:11 PM
LasVegas LasVegas is offline
LasVegas is off the scale
Good for you Albie. And we both "dumbed" out on the no lights, huh?
Jonahs
Old 08-14-2005, 10:15 PM
Albie's Avatar
Originally posted by LasVegas:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Albie:
Good for you Albie. And we both "dumbed" out on the no lights, huh? </div></BLOCKQUOTE>
HEHEH yes we did.
Old 08-18-2005, 02:05 PM
blksunblkmoon's Avatar
blksunblkmoon blksunblkmoon is offline
blksunblkmoon is off the scale
Great Thread!!! used the diode and works like a charm!
old thread so a bump for those who would be interested in the same
LHDH
Old 08-24-2005, 03:21 PM
Viper Viper is offline
Viper is off the scale
Hello Everyone
If I like to have the DRL lights on only at high beam, how do I do the wiring then??
rgds
Tomas
Hummer H2 -03
Dodge Viper RT/10-95
Dodge Viper GTS-96
I live here: http://www.aland.fi/alandinbrief/innehall.htm
Old 08-24-2005, 07:06 PM
Jimstepside Jimstepside is offline
Jimstepside is off the scale
I like the look of the DRLs on with the headlights, but not the park lights. Why can't you jumper the headlight relay instead of the park light relay?
2003 Pewter, SunRoof, Nav, AirHorns, 6 disc in-dash cd changer, B/U camera, ipod
Old 08-24-2005, 09:56 PM
ChuckE ChuckE is offline
ChuckE is off the scale
You can jumper it to any relay you like, even the horn relay if you want . Just use a diode instead of only a wire, that way you don't get any reverse action of the DRLs also turning on the "whatever relay".
\"I asked my wife for a hummer, she gave me this H2.\"
03 White H2 Adventure, sunroof, Garmin GPS, Air Horns, Diablo Sport Programmer
Old 08-24-2005, 10:46 PM
VTSTOMPER is off the scale
I think I might go pick me up a diode baby!
I will do this tomorrow! I think I will be doing the low beam and DRL combo!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 08-25-2005, 03:49 AM
Hello everyone
I tried to get the DRL:s on at high beam only like this (only the blue line) but that was wrong. Anyone knows how to do it?
rgds
Tomas
Hummer H2 -03
Dodge Viper GTS-96
Old 08-25-2005, 04:22 AM
OEM DRLs are for sissies.
GOT PIAA?
Old 08-25-2005, 04:45 AM
dochummer's Avatar
Originally posted by Viper:
Hello everyone
rgds
Tomas
This should work. I currently have my drl's on with headlights-low. You could easily switch that to Highbeams....with the blue line. I guess I may try using a line to the highbeams along with the low beams, so they don't shut off with high.... I haven't tried the blue line yet, so let me know if it doesn't work...
'03 H2
Old 08-25-2005, 07:22 AM
Hello dochummer
Thanks, I will try tonight. I will let you know.
rgds
Tomas
Hummer H2 -03
Dodge Viper GTS-96
Old 08-26-2005, 05:26 AM
Hello dochummer
Thanks, it works with the wiring like the blue line.
rgds
Tomas
Hummer H2 -03
Dodge Viper GTS-96
Old 08-28-2005, 05:14 AM
dochummer's Avatar
Glad to know it worked!
'03 H2
Old 09-05-2005, 09:50 PM
kazarw kazarw is offline
kazarw is off the scale
DOCHUMMER,
I want to have my DRLs on during the day and at night with my low beams. I don't want the parking lights on during the day only at night.
SHOULD I:
Jumper the drl and low beam relays as shown above in yellow only? No other connections?
Also which way does the stripe on the diode face towards the drl relay or the low beam realy?
THANKS...this is a great mod!!!
Old 09-07-2005, 03:38 AM
dochummer's Avatar
Check your pm...
'03 H2
Old 09-16-2005, 06:57 PM
Sportsdude's Avatar
Sportsdude Sportsdude is offline
Sportsdude is off the scale
Originally posted by kazarw:
DOCHUMMER,
SHOULD I:
By doing this with a wire rather than diode, does the low beam remains on with DRL also at all times in "auto" light setting during day and night?
2005 H2 SUV (Yellow)
2003 Vert Supercharged
Old 09-16-2005, 09:19 PM
dochummer's Avatar
Yes. The wire will allow the current to flow both ways so the drls will also activate the headlights during the day. The diode is pretty cheap...I think less than a buck for two.
I think the side with the mark faces towards the DRL relay. I can't see the mark anymore d.t. the way I've set it up.
Here's the relay: RadioShack (part No. 276-1102 "1N4003 Micromini Silicon Diode")
'03 H2
Old 09-17-2005, 06:33 PM
Sportsdude's Avatar
Dochummer, Sir Thank you.
