Old 03-29-2005, 10:32 PM
Ok, so went the dealer today and found out a few things.
Check engine light was on- replaced bad gas cap.
Headliner was loose- reaplced retainer.
Sunroff leaks- There was a wiretie (sp.?) stuck into one of the drain holes. they told me that ll of the H2 sunrrofs leak when water is puddled on top and that's why their are drain holes. My drain holes weren't allowing for the water to drain fast enough.
not sure I like what I was told, but we'll see what happens. I have to have a tone of water up there for it to leak or balst it with a hose dirrectly for it too leak now and it's only a few drops. So under normal situations, i think I should be fine. Any takes/ comments/ concerns?
Old 03-29-2005, 11:08 PM
LasVegas LasVegas is offline
LasVegas is off the scale
My comment is that it shouldn't leak at all...period. I would not accept that Tim.
Jonahs
Old 03-30-2005, 03:02 PM
Hummertech is off the scale
If the drain tubes are not restricted, you can puddle as much water as you want on top of that sunroof and it should not leak.
Old 03-30-2005, 03:50 PM
tower's Avatar
tower tower is offline
With a small leak, should you travel to the snow, overnight freezing will solidify and expand whatever water is in the leak. Since water has the unique property of occupying more volume as a solid than a liquid (that's why ice floats), the leak will be forced to expand each time this happens. That’s why were all saying, despite the hassle of going back with this complaint again, get them to fix it right. You'll be happy you did when your warranty expires.
