Old 03-20-2005, 07:11 PM
Damn it! First problem poped up.. or I should say in. Parked in the driveway. It's on a hill that faces downward away from the house. when running the hose over the roof (not dirrectly on the sunroof either) the wind deflector fills up with water. than it comes into the truck onto the dash. M.F'r
I check to see if it was the marker lights; it wasn't.
I checked to see if it was the antenna on the roof; it wasn't. The water comes in through the sun roof somewhere in the front.
I'm sure this insn't the first sunroof to have water coming in either.
So here's my Questions.
1) is this a simple fix? replace sunroof gasket?
2) how does the sunroof come out? from the inside or pull up from the outside?
Yes, the dealer will be doing this, as it only has 2200 miles, but the rack is going on Monday. If the sunroof has to be pulled from the outside, i can just see some dumbass screwing up all the wiring on the lights.
Any thoughts?
