Old 03-27-2006, 09:14 PM
bigdog100 bigdog100 is offline
bigdog100 is off the scale
New here!!!!
I have a H3 with 6CD XM Mosoon stereo and I am looking to install the Eclipse or Pioneer Navigation sysytem. I went to a car audio showroom and they said I need to bypass the GM amp., but I cannot find the AMP under the seats. Why do I have to bypass it? Is there a harness that will hook into the monsoon amp that will work with Navigation? Thanks
H3 slate blue, lux package, off road package, sunroof, chrome
Old 03-27-2006, 09:24 PM
fourfourto's Avatar
I dont have a monsoon but I beleve you can. Check the find button alot of info on this.
Post some pics if you get a chance
Old 03-27-2006, 09:28 PM
nmikes nmikes is offline
nmikes is off the scale
its in back where the sub-woofer is. You have to dismantle the inside quarter panel... Check the find, there have been past threads on how to get to it.
Old 03-27-2006, 09:48 PM
sub-woofer
Do I have to bypass the amp? Can I use a Chine(think thats what it is called)
Old 03-27-2006, 09:57 PM
k9tim
I had the 6disc Monsoon in mine and KodiakZ installed a Eclipse NAV/Cam last week- I believe he just used an interface that utilizes the Monsoon amp. I could be totally wrong but I expect he will porbably chime in here once he spots your message...
Old 03-27-2006, 10:14 PM
I see his name on a lot of the tech posts. You like the eclipse? Where did u buy it from?
Old 03-27-2006, 11:14 PM
BACKNBLACK's Avatar
BACKNBLACK BACKNBLACK is offline
BACKNBLACK is off the scale
Here is a link to my website and the instructions on how to remove the rear panels. Courtesy of F5.
-Peter
http://www.hummercor.com/H3PANEL.htm
CURRENT HUMMER:
Number# 11 2007 H3x Desert Orange
SOLD BUT NOT FORGOTTON
1995 H1 350 HT GAS Black
2001 H1 Open Top Black
2004 H2 SUV Yellow
2004 H2 SUV Black
2005 H2 SUT Black
2006 H3 ADV Black
2006 H3 ADV RED
2008 H2 Black/Sedona
2009 H3T Alpha Solar Flare
Old 03-28-2006, 12:56 AM
k9tim
Kodiakz has a car audio install biz, so he did the entire thing turnkey including supplying the unit. He showed up at my office, installed everything, ran me thru the finer features and I was on my way home.
I am loving the eclipse! It sounds much better than the stock system, the rear cam is invaluable,the iPod adapter- although quirky- is great once you learn it, and I am very happy with the entire thing.
Old 03-28-2006, 09:43 AM
fourfourto's Avatar
X2 even without the monsoon.
k9tim Did you hook it up so you can watch dvds in motion? A must ,you get full navigation control also.
Old 03-28-2006, 01:01 PM
k9tim
ummmm......
Well there was one wire that I disconnected after Kodiak was done and gone.
Then I happened to ground it out
Old 03-28-2006, 01:26 PM
fourfourto's Avatar
Leave it hooked up to parking brake and also ground out through a hidden switch, that way it looks legal if needed.Some one says you were watching a dvd and crashed you could hit the switch and tell the cops the rear camera was on.
Old 03-28-2006, 09:06 PM
What wire harness did you guys use? How did you run the rear camera?
