Old 02-16-2006, 12:34 AM
So, I used a Rancho 5000 as a steering stab and mounted it just like stock. I've seen some mount them with the aftermarket mount where it has the u-bolts. Is the u-bolt setup where the problems lies?
If so, I should be good to go, then.
Old 02-16-2006, 02:49 AM
Yes, at least on the Fabtech one as it uses a plate at the idler arm, and has a hole in it for the idler nut, so it's got to go.
Fabtech also use a different bracket at the other end which fouls on the Cognito support.
If you are using the stock mounts, there should not be a problem. </div></BLOCKQUOTE>Cool, I just ordered a set and will report back when I get them on.
Old 02-16-2006, 03:45 PM
This is what the Fabtech steering stabilizer mount looks like that causes problems.
[img]http://www.*******club.com/temp/stab_mount.jpg[/img]
That's different from the OTHER Rancho setup. So, I'm betting that the Rancho stabs would work, regardless.
It doesn't have that "plate" around the nut, I don't think.
Phil I think you might could check one of the Rancho stabs and see if you can replace your Fabtech stab with it. It's a universal mount and "clamps" around the center link, I guess further inboard of the nut.
Old 02-21-2006, 07:31 PM
I need a new mechanic and I hate Trail Duty, Hummer and Cognito right now. That is all!
Damn idler arm
Old 02-21-2006, 07:39 PM
You didn't shear it, did you?
Old 02-21-2006, 07:58 PM
No, read Phil's next post and you'll get the jist of it. You know it takes me six years to do something.
I removed the idler arm support bolts first and it moves everywhere when I try to work on the arm nut so I had to put it back in place and the wrench makes about an 1/8 turn each time.
I hate when I don't get to use an impact or air ratchet or something.
Old 02-21-2006, 08:00 PM
If you haven't already figured it out, some really strong arms come in useful for carrying around those 105lb nuts.
Fizzed.
Old 02-21-2006, 08:36 PM
Idler side is on. Had to take a break. Whew!
Old 02-21-2006, 09:37 PM
Pitman side is a piece of a cake, took 10 minutes. 32mm long handled wrench to remove the big nut, 24mm I think for the smaller one.
Does this one fit, no.... does this one fit, no.... does this one fit, no... does this one fit, yep. That's my system.
I don't think I have a 32mm, damn. What is that, like 1 1/2 inch.
Old 02-21-2006, 11:10 PM
300mm (12") adjustable will do the job. May need a rubber mallet to tap it off though. </div></BLOCKQUOTE>I'm still on my break
Old 02-22-2006, 05:15 AM
Paragon: Posted 02-21-06 05:10 PM
Still on break?
