01-31-2006, 02:47 PM
Have not used or seen this used... looks like the concept is good and makes sense. I think my pitman arm is going out as my H2 likes to follow wheel ruts in the road now.
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
01-31-2006, 03:36 PM
Interesting
01-31-2006, 05:35 PM
So is the claim that "alignment ... can not be held" without the product real? I only ask because every time I've had alignments it feels great for a couple hundred miles and then it reverts to being a rut climber. Or do they mean there's too much slop and their product eliminates this slop?
'03 pewter base H2
01-31-2006, 06:37 PM
It's the slop, but slop can cause alignment problems since the system isn't "tight."
$200 for a couple of brackets seems steep though, unless they guarantee the pitman/idlers.
01-31-2006, 06:55 PM
They're just stabilizing the arms. I have a sneaky feeling that could be done for a few bucks and sometime at a good hardware store. Now I think I'm going to slide under there and take a look.
01-31-2006, 11:00 PM
$200 isn't anything if they really work. If it saved 2 alignments, you would nearly pay for them. If it saves the arms, then much better.
Everyone knows there is a premature wear issue even running stock tires on GM HD trucks. I can see the idea behind how these work IF the premature failure is caused by the front/back flex at the arms.
Sounds like someone like Trail Duty could check with them on a group buy for some of us to try out and see if they work.
01-31-2006, 11:03 PM
if phil gets them i'm in for a test of them.
02-08-2006, 10:22 PM
Originally posted by PhilD:
I've ordered one and will install one as soon as I get it and do a write up and let you know how it works.
I assume this means you'll be looking for it to:
1) immediately, take up some of the steering slop
2) in the moderate term, allow you to hold alignment better
3) longer term, reduce pitman/idler arm wear
So we'd have a good idea on #1 and #2 in the near future. Correct?
'03 pewter base H2
02-09-2006, 06:05 AM
I've ordered too ...
02-09-2006, 03:14 PM
Phil, do you lose your alignment because of wheeling, or does it just go out?
02-09-2006, 03:28 PM
I lose my alignment very quickly just driving on the street. It's not out really bad, but enough for me to easily notice. Most people wouldn't, but I'm a bit more discerning.
'03 pewter base H2
02-09-2006, 03:30 PM
Ken, "tomp" is the subject matter expert on alignments.
02-09-2006, 03:44 PM
NOOOO...It says it must be installed by a professional mechanic!!!
It also states that it should take 45mins to a hour, so that means it will be an all day job for Phil!
www.meatspin.com
