Old 09-12-2005, 07:45 PM
VTSTOMPER is off the scale
Who has added them? I am getting a set soon with the harness...anything I should watch for?! Switch locations? I am thinking by the front map lights...probably on the side or facing the rear.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-13-2005, 02:13 AM
I just had the PIAA's installed on my GOBI. I had them mount the switches on the side of the ctr. console. This way any error in measuring and layout would not be visible. The switches are mounted so you push the switch forward, not up or down, to turn on.
Seal the rubber gromet you punch through at the marker light. I need to check mine. I don't want a leak.
Old 09-13-2005, 10:25 AM
Sounds good!
I wanted to go through the marker lamp gromet, but I just wanted to be sure that was the way to go! I will drop some sealer on it after too! Maybe I will take photos as I go.
I always say that, but then I get excited and just do it.
Old 09-13-2005, 12:02 PM
TXSUT's Avatar
TXSUT TXSUT is offline
anything I should watch for?! </div></BLOCKQUOTE>
Yes, low-clearances overhead.
Old 09-13-2005, 12:19 PM
I know right?!
I am going to have to be careful on the back roads this winter. Pines hand lower than low! The State/town does not trim, and when there is an ice storm trees bend to the ground.
Old 09-14-2005, 03:53 AM
I know right?!
I am going to have to be careful on the back roads this winter. Pines hand lower than low! The State/town does not trim, and when there is an ice storm trees bend to the ground. </div></BLOCKQUOTE>Carry a chainsaw.
Old 09-14-2005, 10:20 AM
So many people do that!
We will have thunderstorm or something...it will blow a tree down, and in less than a second there is like 3 guys with chainsaws all over it. It is like they knew it was going to happen! LOL
Old 09-15-2005, 08:59 PM
4churchill is off the scale
We will have thunderstorm or something...it will blow a tree down, and in less than a second there is like 3 guys with chainsaws all over it. It is like they knew it was going to happen! LOL </div></BLOCKQUOTE>
Good 'ol Vermont...how far are you from Quichee? We used to have a place there and would ski at Okemo...I miss winter weekends there. Cold as **** but way too much fun
www.HUMMERNut.net
Old 09-17-2005, 01:48 PM
ROFL!
I am about 20 minutes from Okemo...and about 45 Minutes from Quichee. It does get cold as a mofo around these parts...oddly enough not too many people have block heaters.
Old 09-17-2005, 05:10 PM
Yeah, we belonged to the Quichee club....it's really beautiful there in the summer too!!
www.HUMMERNut.net
Old 09-19-2005, 10:27 PM
Big Jag's Avatar
Big Jag Big Jag is offline
Big Jag is an unknown quantity at this point
I have the Delta 10x light bar and highly recommend it. I think you can light up 2 blocks with it. Have the 2 switches for the Delta (each switch controls 4 lights) and the 1 switch for brushguard lights in a row in front of the map lights in the upper console. Only negative on the Delta is cost, its expensive.
Big Jag
05 H2 (sold)
