Old 08-26-2005, 06:47 PM
primal-hunter primal-hunter is offline
primal-hunter is off the scale
Has anyone found a shorty replacement antenna for the H3? The current one is too long and hits the roof of some garages.
I have tried the auto stores with no luck. The screw end is a 7 mm.
Any advice would be appreciated. Thanks
Old 08-27-2005, 12:29 PM
Vegas-H3 Vegas-H3 is offline
Vegas-H3 is off the scale
I think it is the same as the H2, but not sure. In any case, I know someone who has one on their H3. I will find out the brand along with pics if possible. (IMO, it does look a lot better than stock).
Old 08-30-2005, 01:15 AM
mightypuck mightypuck is offline
mightypuck is off the scale
Try this website: http://www.antennax.com/ the 15" OEM whip replacement mast. They are sending me one to try on the H3. I will post pics once installed.
Old 08-30-2005, 02:05 AM
tony d tony d is offline
tony d is an unknown quantity at this point
http://www.gstylehummer.com has them
Old 09-09-2005, 12:45 AM
Here's a shot of my H3 with the 15" OEM whip replacement mast from AtennaX.
Old 09-10-2005, 01:23 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by mightypuck:
Here's a shot of my H3 with the 15" OEM whip replacement mast from AtennaX. </div></BLOCKQUOTE>
How's the reception? Will that rubber cap come off if you hit a branch or anthing or is it secure? What part number?
Old 09-11-2005, 01:53 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">How's the reception? Will that rubber cap come off if you hit a branch or anthing or is it secure? What part number? </div></BLOCKQUOTE>
The reception is good. The rubber cap is secure. The SKU # is AX-16 (15" OEM Replacement Mast). $14.99 on http://www.antennax.com
Old 09-11-2005, 02:05 PM
VTSTOMPER is off the scale
I had that same shorty on my GMC...it worked well (was able to get it at K-Mart). With my H2 I cut about 6 inches off with a hack saw. I then put the little ball back on. Works like a champ!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-12-2005, 01:41 AM
I had that same shorty on my GMC...it worked well (was able to get it at K-Mart). With my H2 I cut about 6 inches off with a hack saw. I then put the little ball back on. Works like a champ! </div></BLOCKQUOTE>
Did the same on mine! LMAO! But I used an old pair of wire cutters.
Old 09-12-2005, 03:44 PM
Did the same on mine! LMAO! But I used an old pair of wire cutters. </div></BLOCKQUOTE>
Man you have some good wire cutters...mine had a big dent in them after I tried that. They never let me down til that moment. I then had to heat the end of the antanna up with a blow torch, and hit it with a hammer to make the ball fit back on! Worked like a champ! Then I painted it black again!
Old 09-12-2005, 09:50 PM
WPBGUY WPBGUY is offline
WPBGUY is off the scale
Check eBay they are there, lts of them, they run about $15 and are 15" tall
Old 09-22-2005, 12:49 PM
TorontoJeff TorontoJeff is offline
TorontoJeff is off the scale
I just installed the antennax shorty antenna. Looks fantastic, dont hit on garage door anymore and reception is at least equivalent and maybe better than before. I recommend.
Old 09-22-2005, 03:10 PM
DarthKarl's Avatar
DarthKarl is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TorontoJeff:
I just installed the antennax shorty antenna. Looks fantastic, dont hit on garage door anymore and reception is at least equivalent and maybe better than before. I recommend. </div></BLOCKQUOTE>
I've done the same. It works great and gives the H3 a more polished look.
Old 09-29-2005, 09:52 PM
I put the antennax shorty antenna on and i did a test with distant stations on both FM and AM by changing antennas.
My estimation is the short antenna is slightly less effective than the larger one.
Old 09-30-2005, 01:59 PM
MyxH3 MyxH3 is offline
MyxH3 is off the scale
Thanks for the posts I just ordered one myself
May the next exit offroad be anywhere you want it to be.
Old 10-05-2005, 12:24 AM
jp's-h3 jp's-h3 is offline
I've had my shorty antenna for a few weeks. A great addition, awesome reception, looks great! Two thumbs up!
Old 05-12-2007, 10:19 PM
SHYANNE SHYANNE is offline
SHYANNE is on a distinguished road
Default Re: Shorty Antenna Replacement
do you still have to take it off at the cars wash or will it not get hung up ? mine did the long one today.i would thing its short enogh.
Old 05-14-2007, 03:06 AM
Groundpounder Groundpounder is offline
Groundpounder is on a distinguished road
I got a Bullit one off of eBay, however, the end screws were to big or not the right thread. I installed the old one back on after cutting it short with a hack saw. The car wash kept taking it off and they had a hard time putting it back on due to the threads being messed up. I ended up cutting it to about 3" long, spary-painted it chrome and recscrewed it back on as far as it woudl go. The reception is still good, AM and FM. I am mostly into XM now, so I am not worried about the total reception. When I have tried AM/FM they are still easy to hear.
2006 Slate Blue Metallic H3, FlowMaster exhaust, True Flow cold air intake system, Ground Force rear lowering kit, custom locking fuel door, chrome hood grill w/handle, US Speedo gauge kit (chrome and red numbers), Custom rear tire cover, chrome tail light guard, custom paint on skid plate, new pin stripping, USMC front license plate. Semper Fi
