Old 01-04-2006, 11:46 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
Can anyone tell me, in english I would understand, the benefits of a throttle body spacer. The manufactures description sounds like it's something I need, and for $100.00 it sounds like a good deal.???
WWW.BCBI.COM
hmrlvr's Avatar
WWW.BCBI.COM
Old 01-05-2006, 12:29 AM
Edspad Edspad is offline
Edspad is off the scale
It should increase air flow. thus more air flow + more fuel = HP. Of course this is my understanding of the throttle body spacer add on of the Ford Mustang.
It is a good thing for an uneducated man to read books of quotations. - Sir Winston Churchill
Old 01-05-2006, 02:03 AM
nmikes nmikes is offline
nmikes is off the scale
had one on my f150... I don't know if it was a phsycological thing or not...do know that it whistled like a turbo so you knew it was working... some thought it annoying... I thought it was cool.
Old 01-05-2006, 04:13 AM
DeLeon DeLeon is offline
DeLeon is off the scale
This sounds like a questions for f5stop... and I would also love to read it
\'06 Boulder Gray H3 / Loaded
Old 01-05-2006, 09:29 PM
TB spacer will slightly increase upper rpm HP and slightly decrease lower rpm HP. It's more of a psychological effect than anything. Basically, you're moving the power band up slightly(have I said slightly enough?). Past that, don't look for a noticeable increase in performance.
General rule--the more you spend, the faster you go. In the scheme of things, $100 is only the ante.
Old 01-07-2006, 12:32 AM
WPBGUY WPBGUY is offline
WPBGUY is off the scale
I tried it. Took it out. Sold it on eBay. Made noise and did not fit well.
